1992 honda gets code 41
Old Jun 30, 2005 | 07:10 PM
wirenet
Guest
Posts: n/a
honda accord 1992 gets code 41.I am also getting about 15 miles per gallon
over the road and around town. Honda has 125.000 miles on it. The fuel
checks out okay. The distributor went bad two months ago and was
changed.The plugs were changed and they are black. The car is burning or
losing no oil. The car is not over heating.When the engine is cold like in
the winter the car idles rough. Idle engine is rough on the money.I am
getting no ticking from the valves would this cause bad gas mileage.
Timing was cheked and is okay. thanks
S.S.
Guest
Posts: n/a
Re: 1992 honda gets code 41
Replace the O2 sensor. And make sure the new one is OEM.
Old Jun 30, 2005 | 09:33 PM
wirenet
Guest
Posts: n/a
I am responding to ss I replaced the oxygen sensor with an oem one and it
different make any difference. signed wirenet
Old Jul 1, 2005 | 12:32 AM
motsco_ _
Guest
Posts: n/a
If it's gutless when cold, but OK for acceleration once it warms up, it
may be your timing belt is out a tooth, and somebody has corrected the
ignition timing by rotating the distributor (is it cranked to the
extreme of it's range?) So your ignition timing can be correct, but the
valves timing may be way out.
'Curly'
trolllalor
Apr 23, 2018 08:43 PM
Gula
Feb 22, 2017 12:52 PM
shane
Dec 15, 2012 10:09 AM
davidofva@yahoo.com
Sep 7, 2005 05:33 PM
DANIEL ELLIOTT
May 4, 2005 11:16 AM
