99 Civic starting issue
Old Jul 6, 2005 | 01:17 PM
John Smith
Guest
Posts: n/a
Hello:
My 1999 Civic LX 4-dr sedan has the following problem: when I try to start
the car, it keeps trying but does not actually start. The battery is about
9months old. The car was in my garage for 4days and yesterday when I tried
to start it, no success.
Any ideas what might be the problem? I am planning on having it towed to a
dealership today. I just wanted to be semi-informed on what might be the
issues (and how much they could cost)?
Thanks.
jim beam
Guest
Posts: n/a
Re: 99 Civic starting issue
John Smith wrote:
> Hello:
> Thanks.
when were the plugs last changed? what's the service history? mileage?
Old Jul 6, 2005 | 01:30 PM
John Smith
Guest
Posts: n/a
The car has 47k miles on it. I am the first owner. I have had regular
service done at Honda dealerships...the last was a 45k service which was
done about 4months ago. I went through the paperwork -- it does not appear
as though the plugs were cleaned/changed at that time.
"jim beam" <nospam@example.net> wrote in message
news:DaidnTSnw6_ym1HfRVn-3g@speakeasy.net...
> John Smith wrote:
>> Hello:
>> start the car, it keeps trying but does not actually start. The battery
>> is about 9months old. The car was in my garage for 4days and yesterday
>> when I tried to start it, no success.
>> a dealership today. I just wanted to be semi-informed on what might be
>> the issues (and how much they could cost)?
>> Thanks.
Old Jul 6, 2005 | 02:54 PM
motsco_ _
Guest
Posts: n/a
>>John Smith wrote:
>>>Hello:
>>>Thanks.
Don't have it towed. Parts don't fail while a car is sitting inside a
garage (unless the garage was struck by lightning) Read the chapter in
your manual called STARTING THE ENGINE. You've got a flooded engine
because one injector stuck open, and dribbled gas into the engine while
it was parked. My Odyssey did the same trick to us. Just do like the
manual says, and hold the pedal to the floor, crank it, and release the
pedal when it starts to run. It will blow a bit of black smoke.
Your dealer should know about this. the cure is to run some injector
cleaner thru it, or a couple tanks of Gasohol (see your manual)
'Curly'
jim beam
Guest
Posts: n/a
>>John Smith wrote:
>>>Hello:
>>>Thanks.
standard plugs are rated for 30k - if they were not changed, they are a
prime candidate. if you can change them yourself, you're going to
change yourself a bunch of cash on having the dealer tow & do the same
thing for you.
you could probably translate your savings into one of these:
http://www.midwayautosupply.com/deta...ption.asp?3352
which will save you a bunch of trouble in the future for this or any
other post 96 car you own. first thing any repair shop does is plug one
of these in & get the codes.
SoCalMike
Guest
Posts: n/a
John Smith wrote:
> Hello:
leaky injector could have flooded it? did ya try flooring the pedal
while cranking to let more air in?
> Thanks.
SoCalMike
Guest
Posts: n/a
it was likely done at the 30k service.
John Smith
Guest
Posts: n/a
Thanks for your response.
It was exactly what you said...I had to hold the pedal down fully and crank
it a couple of times. I now need to implement the injector cleaner part of
your message. Any suggestions on brand names for that product?
There was another response saying that spark plugs would have been replaced
at 30k. That is correct. I just looked at my 30k service records.
Thanks again.
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:42CC1840.60609@interbaun.com...
>> appear as though the plugs were cleaned/changed at that time.
>>>John Smith wrote:
>>>>Hello:
>>>>Thanks.
> because one injector stuck open, and dribbled gas into the engine while it
> was parked. My Odyssey did the same trick to us. Just do like the manual
> says, and hold the pedal to the floor, crank it, and release the pedal
> 'Curly'
Frank Boettcher
Guest
Posts: n/a
On Wed, 06 Jul 2005 11:43:28 -0600, "motsco_ _" <"motsco_
>>>John Smith wrote:
>>>>Hello:
>>>>Thanks.
>garage
That's exactly how my igniter failed on my 90 accord. drove it
running fine. parked it for several days and when I tried to restart
it igniter was bad. replaced igniter and all is well. Had about 50K
miles on it when it happened.
>'Curly'
Old Jul 6, 2005 | 06:31 PM
motsco_ _
Guest
Posts: n/a
> Thanks again.
>>>>John Smith wrote:
>>>>>Hello:
>>>>>Thanks.
>>'Curly'
Techron seems to be the 'de facto' standard. It's an American product,
but I don't remember what gas station sells it. I'm in Canada, so I just
filled the sucker up with Mohawk 'PLUS' gas, two tanks must have cured it.
'Curly'
Old Jul 6, 2005 | 11:06 PM
SoCalMike
Guest
Posts: n/a
chevron... techron, techroline, something like that.
> Thanks again.
any time! ive got a 98 myself ive done all the work on. same service
intervals :)
othercarisaminivan
Sep 24, 2005 03:35 PM
Tinob
Aug 25, 2005 11:03 AM
Tinob
Aug 24, 2005 11:34 PM
sstula@hotmail.com
Jun 22, 2005 01:43 PM
442nyx333
