1990 honda civic
Old Jul 8, 2005 | 07:59 PM
edward609va
Guest
Posts: n/a
1990 honda civic
my car overheated about 2 years ago i took it to the shop and they said
that i blew a head gasket, so we let it sit for a few min to cool off then
put some fluid in it and never had a problem since. did it just need fluid
or were they trying to get $900 out of my pocket?
Old Jul 8, 2005 | 10:23 PM
TeGGeR®
Guest
Posts: n/a
Re: 1990 honda civic
"edward609va" <edward609va@aol.com> wrote in
news:0e6ecd54fee52f3b3cb9317f899e7131@localhost.ta lkaboutautos.com:
> said that i blew a head gasket, so we let it sit for a few min to cool
> off then put some fluid in it and never had a problem since. did it
> just need fluid or were they trying to get $900 out of my pocket?
Are you sure you've "never had a problem since"?
How's the cookant level in the rad? Is there ever any air in it?
Does the reservoir level increase, then not go back down?
TeGGeR®
www.tegger.com/hondafaq/
jim beam
Guest
Posts: n/a
this happened to a friend of mine about a year ago. subaru - got towed
home. huge estimate to fix blown head gaskets. lost /all/ it's
coolant. huge mess. i poked about & noticed a piece of gunge under the
blow-off valve in the radiator cap. cleaned it out, refilled, and guess
what? never had a problem since.
so, long story short, yes, your shop was after the $900. just like the
folk that are happy to sell you a new honda transmission at only 90k
miles because "this one is about to go". there's countless other
examples.
Old Jul 9, 2005 | 10:07 AM
Frank Boettcher
Guest
Posts: n/a
Is your temp guage staying steady in the proper range?
Are your cooling fan(s) coming on when they should? (force it on by
holding rpm's up a little on the vehicle while stopped in summer
temps.)
Are you not loosing any coolant over time?
if yes to all, you are probably ok.
You can check compression and also check each plug for the proper
color (to make sure you are not burning a little coolant with your
gasoline). If Ok you should be ok.
I had a vehicle with a blown head gasket was leaking just a very
little coolant into one cylinder. Actually seemed to run better than
before. Only clue was the plug would foul every couple of months and
there would be an almost imperceptable slow coolant loss. If you let
it go, however it will eat up your valve seats on that cylinder head.
On Fri, 08 Jul 2005 19:19:52 -0400, "edward609va"
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
mmdir2002@yahoo.co.uk
Jun 4, 2005 11:09 PM
DaviT
May 4, 2005 04:44 PM
braxmed
May 4, 2005 11:16 AM
karla
