Install Question/Confusion
Old Mar 25, 2008 | 02:30 PM
SpokanejdmGD3's Avatar
So I am looking at the skunk2 spring install how to and I just want to clear up something before diving in.
It says to support the lugs.........I don't know if I have a different terminology or not but is that to mean the wheel studs? That would be my assumption but again I just want to make sure I am doing this properly.
If it is not referring to the wheel studs does someone have a picture of what exactly is meant to be supported.
Thanks
Mike
Old Mar 25, 2008 | 03:42 PM
i believe you're talking about the front to support the knuckle from
falling down to prevent the cv joint from separating.
I use a hydraulic jack and support the knuckle under the knuckle,
not on the lug studs. reason being, it's harder to slip off when you
support the ENTIRE knuckle and also to prevent the stud threads
from being damaged.
Old Mar 25, 2008 | 04:40 PM
OK...........see now that is what made sense to me but beings as the how to said lugs I kept going back to the the studs in which i thought also was a very weak point to support the car.
Thanks...... be back in a couple hours.
Old Mar 25, 2008 | 04:41 PM
Amageus's Avatar
I used a jack and some wire I had lying around tied around the whole thing...i still ended up popping the axle out >.>...but that was kinda my fault lol...but ya...make sure you have something supporting the whole rotor and stuff to prevent your axle from popping out. You could also use some string, wires, w/e to wrap around the wheel studs to give it more support.
Old Mar 25, 2008 | 07:55 PM
i think spokan fell asleep in his garage after the install.
Old Mar 25, 2008 | 09:59 PM
lol na I am done. I just used a jack. had a couple interruptions by the wife so it took me about 3 hours total to get done with an hour of interruption.
Car is f'in slammed! Can't wait to get the new wheels on the car.
Old Mar 26, 2008 | 12:41 AM
claymore's Avatar
Think about it for a minute........ WHAT DO YOUR LUGNUTS SCREW ONTO..... could it possibly be the LUGS ?????????
Old Mar 26, 2008 | 01:54 AM
Ha yeah well that would be why I asked smart guy. If I put the jack on the LUGS/Wheel Studs I'd be putting the weight of on those and thats just asking for them to break.
Old Mar 26, 2008 | 03:42 AM
claymore's Avatar
Well it did say SUPPORT not jack. But anyway they don't break when holding the wheel on either. It probably meant to just keep a little support on the lugs so the arm doesn't hang and pull out the axle.
Just noticed 888 posts ... is that as bad as 666???
Old Mar 26, 2008 | 11:15 AM
no just says you're still a newb.
Steven Hung
Oct 6, 2016 09:21 PM
thefit09
Mar 3, 2013 10:39 AM
Mr08FiT
Sep 25, 2009 07:25 PM
hammy_burgers
Jun 24, 2008 02:26 AM
