VSS diagnosis?
Old Jul 10, 2005 | 03:39 PM
Steve Bigelow
Guest
Posts: n/a
VSS diagnosis?
91 Accord, 301,000kms, 5 speed
The online manual I use (honda uk) is missing the VSS diagnosis pages.
Well, my speedo has turned intermittent. Phooey.
Anything else that might cause it, besides a lousy connection at the VSS?
Anyone know how to diagnosis the Vehicle Speed Sensor?
Thanks
SteveB
91 EX-R, mostly stock...mostly.
CB7tuner.com Ver.2 short/quick shift, Wheelskins wheelcover, Infinity
605CS/692.5, Infinity 12" sub powered by MTX, JVC MP3, shiny-ass mesh grill,
Krazy Kandy Koloured Kam Kover, Energy Suspension engine mount, new clutch,
Magnaflow cat-back, KYB GR-2's, AEM CAI, CM 1.5" springs, Royal Purple
Syncromax, Falken 512/205-55's, Neuspeed strut bar, S/T sways
Old Jul 10, 2005 | 09:16 PM
jim beam
Guest
Posts: n/a
Re: VSS diagnosis?
think that speedo is cable driven on that model, so if it's
intermittent, the connection must be loose/failing.
if your accord is like my civic, to test the sensor, you need to take
out the cluster & put a meter across the output terminals while you
rotate a matchstick in the speedo drive. you'll get conduction & break
as the match rotates.
> Thanks
> SteveB
dasdavid
Apr 15, 2017 02:39 PM
rnlisa
Sep 23, 2005 10:31 PM
Robin Cook
Jul 14, 2005 10:44 PM
Ken W
Jul 1, 2005 02:40 PM
Mark
May 18, 2005 11:20 PM
