Bump stops on rear shocks.
Old Mar 27, 2008 | 07:25 PM
BMX RACR's Avatar
Today I pulled the rear shocks and cut down the bump stops, it made a huge difference in the way the rear rides, it`s alot smoother and not as bouncy.
Old Mar 27, 2008 | 09:18 PM
im assuming you're running lowering springs...
Old Mar 27, 2008 | 09:19 PM
BMX RACR's Avatar
Yea, DF210`s.
Old Mar 27, 2008 | 09:26 PM
cool! nice info.
Old Mar 27, 2008 | 11:22 PM
diedwater's Avatar
cutting bump stop is kinda a touchy thing.
I don't know much about the fit's bump stop, but on some other cars, the bump stop actually acts kinda of as a progressive spring.
when just rolling on the high way, you won't be touch the bump stop, but under hard cornering, you will hit the bump stop, and the spring rate will increase. lets say there r 5 levels or cornering hardness. the harder you corner, the higher the spring rate will be. Say the highest is 800+the spring rate, so you go from 100, 200, 400, 600, 800. But if you cut off half of the bump stop, the minute u go into a hard corner, your spring will stiff up 400lb in a snap.
also, if cut too much bump stop, you are running at a higher risk of blow the seal, since you will have more travel then factory intended.
so, the best way to deal with this is usually buy an aftermarket bump stop kit
those are based on my past experience, so please correct me if I'm wrong.
Old Mar 28, 2008 | 12:11 AM
BMX RACR's Avatar
I have the DF210 springs, 1.8 drop in front. 1.3 drop in rear, I cut 1.8 inch off the front bump stops but the rear shock had a bit more travel so I cut 1.7 off the rear. Now that I`ve done this the ride is much smoother, when I go over dips in the road the rear is not bottoming out and bouncing off the bump stop like before. The rear bump stop is a little over 4 inches long so taking 1.7 inch off of it still doesn`t let it compress all the way down, so this should keep it from blowing the seal.
Old Mar 28, 2008 | 12:21 AM
KoolMikeSki's Avatar
Im curious when you bought the tanabes does it say to cut them? I had Neuspeeds on my accord and they said to cut the bump stops. ... Just curious. I am thinking about getting them.
Old Mar 28, 2008 | 12:24 AM
BMX RACR's Avatar
Yes, the instructions say to cut them.
Old Mar 28, 2008 | 12:38 AM
Cool Thanks
Old Jul 16, 2009 | 08:29 AM
Lek's Avatar
Lek
My friend wanted to go back to stock springs, so off he went to Honda to buy some new bump stops. They sell the front ones in pairs, but not the rear ones. They come with the shock as a unit. STRANGE!!! Where can you buy aftermarket ones online?
Old Jan 20, 2010 | 11:12 PM
matrix02's Avatar
Can anyone confirm whether or not to cut the bump stops with Tein S-tech for GD3? It is not noted on Tein's instructions.
Old Jan 23, 2010 | 06:21 PM
danger69's Avatar
Majority anyone isntalling springs you need to cut the bump stops. As for how much you can follow bmx racr's recommendation since it is very minor.
LaoSiFu
May 30, 2013 01:33 PM
buttersandpaper
Atlanta Community
Jun 1, 2009 12:44 AM
alexfree05
38
Mar 12, 2009 10:36 PM
pwnstar
Oct 15, 2008 09:27 PM
coupdetat
23
Jan 25, 2008 04:12 PM
