Timing belt - mileage vs time
Old Jul 11, 2005 | 06:36 PM
Peabody
Guest
Posts: n/a
For what it may be worth:
I have a 94 Accord (soon to be 11 years old) with only 49,000 miles
on it. Today I went to see Earl, who for the last 15 years has run
a local repair shop specializing in Hondas and Acuras, and who is
highly respected for the quality of his work and his expertise.
Earl said the timing belt is almost exclusively a mileage item, and
he would not recommend replacing mine until I reach 90k miles,
pretty much no matter how long that takes. He said failures at
fewer miles are extremely rare, and he routinely sees low-mileage
early 80's Accords which still have their original timing belts.
Earl had the opportunity to relieve me of several hundred dollars,
since I went in to schedule the belt replacement, but he pretty
firmly turned me down. So, I assume he at least believes what he's
saying, even if he may not be right.
Old Jul 11, 2005 | 07:35 PM
SoCalMike
Guest
Posts: n/a
Re: Timing belt - mileage vs time
id likely believe him,... ive got 49k on my 98 CX, and am in no
particular hurry to replace the belt. i doubt ill wait til 108k, but 90
sounds reasonable if i still ahve the car. part has to do with the
weather the car is driven in, how its stored, etc. i park in a garage.
FWIW, i change all my fluids every 3 years, and they always come out
looking almost as clean as the new stuff.
Dave Garrett
Guest
Posts: n/a
In article <4ZBAe.55676$iU.49281@lakeread05>, waybackKILLSPAM44
@yahoo.com says...
My experience has been different. I replaced the t-belt on my '90 CRX Si
at 60K miles. Last year, at around 115K miles, it occurred to me that it
was nearing time to replace it again, and resolved to do so as it got
closer to the 120K mile mark. Shortly thereafter, it failed while I was
on the freeway. Fortunately, I was able to coast into the breakdown lane
safely, and even more fortunately, the valvetrain wasn't damaged.
It had been seven years since it was replaced at 60K (my daily commute
is short, hence the relatively low mileage on the car for its age), and
the snapped belt had dry-rotted badly enough to where it was easy to
strip teeth off it with my bare hands. Now, I live in an area with high
humidity, very hot summers, and mild winters, so you might consider that
to be the "extreme conditions" Honda typically stipulates a different
maintenance schedule for. But when I told my mechanic how long it had
been since the 60K replacement, he said he would be reluctant to trust a
t-belt for much more than 5 years regardless of mileage. Perhaps the
newer belts are constructed differently, as the maintenance interval for
most of them has gone up in recent years.
As always, YMMV. Especially when it comes to t-belts. :-)
Dave
Old Jul 11, 2005 | 08:57 PM
S.S.
Guest
Posts: n/a
That's what I was thinking. Perhaps changing the belt based on time is
recommended for so-called "severe" conditions such as winter weather.
Old Jul 11, 2005 | 10:03 PM
Elmo P. Shagnasty
Guest
Posts: n/a
In article <0_2dnQTrA4t_Z0_fRVn-gw@comcast.com>,
Ah. Because you don't WANT to replace the belt, you've chosen to
believe someone who confirms what you want to do.
Got it.
Old Jul 12, 2005 | 12:11 AM
TeGGeR®
Guest
Posts: n/a
Peabody <waybackKILLSPAM44@yahoo.com> wrote in
news:4ZBAe.55676$iU.49281@lakeread05:
Timing belt replacement: $200 or so.
Engine work if the belt breaks: can be $2,000.
Yes, it's true. Honda is conservative with their timing belt intervals. But
then again, Hondas are interference engines. Your chances are about even
for serious damage if the belt breaks.
To me, $200 is worth the peace of mind.
TeGGeR®
www.tegger.com/hondafaq/
Nightdude
Guest
Posts: n/a
Honda always recommended a time with their timing belt change. I believe
it's 5 years.
"duckbill" <ltcauth13@nospam.cs.com> wrote in message
news:c5f806714664bcc139c1f20349f82a52@localhost.ta lkaboutautos.com...
> High milage in my opinion is not the only killer of timing belts. Heat /
> below freezing temps. and starting the engine put a lot more stress on the
> belt than driving on long trips. You also have a tensioner pulley that
> may
> have the grease drying out. And the biggest issue is that Honda's are not
> free-wheeling engines. Normally, when the belt breaks, pistons and valves
> collide. Will Earl stand by you with assistance if your belt breaks
> before its scheduled milage interval? And will he put it in writing?
> Honda is now recommending a time as well as milage interval. Good luck on
> your decision.
Nightdude
Guest
Posts: n/a
The belt might not snap, but your water pump might seize and cause the belt
to snap!
And remember, heat and environment make rubber brittle, especially after 11
years.
When I changed my belt at 90K on my car, the water pump was almost shot, it
was slowly leaking and the bearings were making a loud noise. Without taking
the belt out, I wouldn't have known.
My car is also a 94.
"Peabody" <waybackKILLSPAM44@yahoo.com> wrote in message
news:4ZBAe.55676$iU.49281@lakeread05...
duckbill
Guest
Posts: n/a
belt than driving on long trips. You also have a tensioner pulley that may
your decision.
motsco_ _
Guest
Posts: n/a
Earl is honest, but mis-informed. Please read this:
http://www.tegger.com/hondafaq/faq.html#interference
'Curly'
Steve Bigelow
Guest
Posts: n/a
"Elmo P. Shagnasty" <elmop@nastydesigns.com> wrote in message
news:elmop-7E053C.21055611072005@nntp1.usenetserver.com...
> Got it.
So at 7k a year, he'll wait until nearly 13 years on the original belt.
Yikes.
You figure you'll change it by 2011, do you, Mike?
Old Jul 12, 2005 | 02:46 AM
Rattus The RAT
Guest
Posts: n/a
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9690F1CD1D7EDtegger@207.14.113.17...
> But
$200! You know a good place man! Any such places around DFW?
RAT
Old Jul 12, 2005 | 07:11 AM
SadaYama
Guest
Posts: n/a
>Nightdude
>The belt might not snap, but your water pump >might seize and cause the belt to snap!
>And remember, heat and environment make >rubber brittle, especially after 11 years.
I agree with what this Nightdude says. Unless you have garaged your car
at room temperature, you need to replace the belt because the extreme
heat under the hood and cold makes the rubber brittle. Not just the
timing belt but also alternator, powersteering and water pump belts,
including the water pump, even if it is not broken -- because it costs
same amount of money to replace a H2O pump as replacing a timing belt.
Old Jul 12, 2005 | 03:30 PM
Pete from Boston
Guest
Posts: n/a
> > But
$200? I paid maybe $300 on my 1987 Accord, had the dealer do it free on
my present 1990 Accord at 46,000 (car was 8 years old then), and am
expecting $600 to have the belts and water pump done on the same car
now at 143,000. But if it comes in under, even better.
Old Jul 12, 2005 | 04:32 PM
TeGGeR®
Guest
Posts: n/a
"Pete from Boston" <masspete@my-deja.com> wrote in
news:1121194232.658041.18480@g44g2000cwa.googlegro ups.com:
>> > intervals. But
>> > even for serious damage if the belt breaks.
> on my present 1990 Accord at 46,000 (car was 8 years old then), and am
OK, OK, OK. Everybody keeps telling me I keep quoting high, so this time I
quoted low.
However, notice my weasel clause: "...OR SO". So I'm covered. :)
TeGGeR®
Old Jul 12, 2005 | 07:55 PM
Rattus The RAT
Guest
Posts: n/a
news:Xns96919F88EC31Ategger@207.14.113.17...
>>> > intervals. But
> quoted low.
When i got mine done last year I called maybe 10 places and cheapest quote
i got was around 495 OR SO!
Old Jul 13, 2005 | 12:05 AM
Alex Rodriguez
Guest
Posts: n/a
My family has an '88 Accord with 45k miles. The belt has never been changed.
I probably won't get to it till next year.
Alex
Old Jul 13, 2005 | 01:51 AM
jim beam
Guest
Posts: n/a
i've spent a whole lot of time in junk yards over the years [a great
place to see a lot of failures] and gotta say, it's pretty unusual to
see a [honda] timing belt that's in such bad condition that i'd be
concerned about failure just through age. theoretically, yes, belts
crack, belt fibers fatigue and teeth fall off, but this is seldom
without any form of visible deterioration. i say, do a visual
inspection. if it apears to be in bad shape, cracking, fraying, teeth
worn or deformed, yes, replace regardless of mileage. but if it's not,
and you /know/ for sure mileage is within spec, i'd stick with earl's
advice.
SoCalMike
Guest
Posts: n/a
> advice.
id be curious to know how many 80s/90s vintage civics *ever* get their
timing belt replaced. its something 99% of people dont even think about.
im sure some live their whole lives with one belt, then it gets replaced
when the water pump starts spewing coolant.
Old Jul 13, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
>> not, and you /know/ for sure mileage is within spec, i'd stick with
>> earl's advice.
from the junk yard viewpoint, i'd say pretty much never. at the bottom
end of the market, does it make sense to spend $300 on a $500 car?
people just keep running those cars until they break. and you'll not
see many junk yard clunkers with broken belts.
