Exhaust help
Old Jul 13, 2005 | 12:05 AM
Alex Rodriguez
Guest
Posts: n/a
Exhaust help
I decided to do a good deed and change the rusted center pipe on my inlaws 88
Accord. Of course this is turning into a bigger job than expexted. I finally
got pipe out but cutting and grinding the bolts that held the pipe to the cat
convertor. I thought I could just push the bolts out, but apparently not. Any
tips on getting these bolts out?
Alex
Old Jul 13, 2005 | 01:51 AM
jim beam
Guest
Posts: n/a
Re: Exhaust help
> Alex
the bolts are captive & come with the pipe. oem pipe anyway. if you
can seperate the pipe from the converter, you should be in business for
replacement.
Old Jul 13, 2005 | 08:31 AM
Abeness
Guest
Posts: n/a
Re: Exhaust help
>> inlaws 88 Accord. Of course this is turning into a bigger job than
>> expexted. I finally got pipe out but cutting and grinding the bolts
>> that held the pipe to the cat convertor. I thought I could just push
>> the bolts out, but apparently not. Any tips on getting these bolts out?
>> Alex
> replacement.
The bolts between converter and center pipe (Pipe B) are actually
separate, and are called "converter bolts". On my 94 Civic these are
specialty bolts (not cheap, same for the 88 Accord) that have a thin,
flat head and "ridged" spine designed to grip in the holes in the
converter and help prevent the bolt from turning as you apply the nut.
I tried to get mine out but found that the rust was more than I could
handle with my equipment. Mechanic charged me $75 to do it. Maybe try
heat and hammering them out with a punch from the Pipe B side? Just be
careful not to pound so hard that you damage either the cat or Pipe A,
both of which cost a lot. Might be better to drill them out.
Old Jul 13, 2005 | 09:30 AM
butch burton
Guest
Posts: n/a
Re: Exhaust help
I used a 5" angle grinder (wear a full cover face mask when doing this)
and cut them off both ends of the cat - both nut end and bolt end.
Removed the pipes and cat and drilled out the bolts in the cat and
replaced them with new bolts. Be careful with the cat sensor - it will
disconnect.
Old Jul 13, 2005 | 10:32 PM
Alex Rodriguez
Guest
Posts: n/a
Re: Exhaust help
In article <G6CdnRyf5Jo1CEnfRVn-oA@speakeasy.net>, nospam@example.net says...
>replacement.
I got the pipe off after much effort. Unfortunately it looks like the bolts
are captive on the cat converter, which I am not changing. I guess I will be
grinding and drilling. I hope there is enough room to put in bolts once I
grind them off. Thanks.
Alex
Old Jul 13, 2005 | 11:30 PM
Alex Rodriguez
Guest
Posts: n/a
Re: Exhaust help
In article <SKednQUqVMpKlUjfRVn-gw@rcn.net>, news@nada.x says...
Thanks for the tip. I tried pounding on the bolts with a hammer, not a big
one, and they bolts would not budge. I tried drilling them out, but my drill
bits were not up to the task. I'm going to buy a couple of decent bits before
I try again this weekend. Since I am going to drill them out, I'm not going to
bother with the special bolts.
Alex
jim beam
Guest
Posts: n/a
Re: Exhaust help
> Alex
ordinary bolts will soften & creep at high temperature. and the exit of
the cat is /very/ high temperature!
Old Jul 14, 2005 | 03:45 PM
Guest
Guest
Posts: n/a
Re: Exhaust help
"jim beam" <nospam@example.net> wrote in message
news:Btidna_Ie7MtT0jfRVn-vA@speakeasy.net...
What is the difference between ordinary bolts and the ones you refer to,
Jim?
Old Jul 14, 2005 | 06:31 PM
SoCalMike
Guest
Posts: n/a
Re: Exhaust help
> Jim?
the OEM bolts are splined to stay snug in the hole. right?
Old Jul 14, 2005 | 07:50 PM
Abeness
Guest
Posts: n/a
Re: Exhaust help
>> Jim?
Ahh, is THAT what it's called. Yes, they are splined. The shop that got
the old ones out for me was apparently able to get them out without
making the holes too big to grip the spline--I'd be careful about that
if you're drilling them out. Pretty heavy-duty little suckers,
too--though short, they weigh several ounces at least (3 of 'em,
anyway). No wonder they were some $7 each.
Old Jul 14, 2005 | 08:56 PM
jim beam
Guest
Posts: n/a
Re: Exhaust help
> Jim?
should be an alloy better able to take the temp. if you go to extremes,
you use cast components too.
Old Jul 19, 2005 | 05:31 PM
Alex Rodriguez
Guest
Posts: n/a
Re: Exhaust help
In article <1121258086.164078.203220@g49g2000cwa.googlegroups .com>,
spacetrax@wi.rr.com says...
>disconnect.
This is what I ended up doing. The grinder went right through the bolts.
I then drilled out what was left. One important piece of advice I would
pass along to anyone doing this job is to pull the exhaust system out of the
car. The bolts that hold the exhaust to the header pipe came off very easily.
Once I had the pipe/cat conv. out it was much easier to to the work. I used
bolts I got at the autoparts store that were marked 8.8. I'll see if they
really do succumb to the hear from the cat conv and fall apart.
Alex
Bthasht
14
Apr 22, 2021 02:46 PM
Myxalplyx
Mar 24, 2021 11:15 PM
ZiaMan
Oct 18, 2015 03:29 PM
Demon Fit
Jun 5, 2011 10:06 PM
HND
Jul 25, 2005 03:30 PM
