Shock absorber header ring
Old Apr 3, 2008 | 04:22 PM
alexfree05's Avatar
Did anyone do that for your fit?
http://www.hondafitjazz.com/ring.htm
how's the outcome?
where can i find those "rubber board" online??
Thanks
Old Apr 3, 2008 | 04:25 PM
huh, if anything it should be on the other side of the tower if you're
going for comfort, no?
but the other side is a conal shape so you can't put that on...
if you want comfort, just get the EnduraTechs.
Old Apr 3, 2008 | 04:26 PM
also, that wrench is not a normal wrench. it's called a offset box wrench.
Old Apr 3, 2008 | 08:41 PM
mahout's Avatar
[quote=alexfree05;273671]Did anyone do that for your fit?
how's the outcome?
I don't see any advantage but why not get 4 more bushings from your Honda parts department and add one under and over on each side.
Old Apr 3, 2008 | 09:13 PM
08FitSport's Avatar
how's the outcome?
Thanks
Looks like it's a vibration damper. You should look up sound deadening in the ICE threads.
Old Apr 3, 2008 | 09:38 PM
if it's for sound dampening might be better just removing the strut,
masking off where the lower half of the strut mount would go,
spray the inside fender metal with sound deadening spray.
remove the masking tape, install your strut back on.
Old Apr 3, 2008 | 10:37 PM
08FitSport's Avatar
That does sound better so if the top idea works(easier) I'd follow up with your idea. Thanks
siccmonkey
21
Feb 29, 2012 01:28 AM
fitted08
King Motorsports
Nov 10, 2010 08:46 PM
B-boystance
European Fit Forums & Clubs
May 10, 2009 05:40 PM
kancerr
13
Sep 25, 2008 06:19 PM
iheartmyGD3
Oct 21, 2007 08:59 PM
