View Poll Results: What do you do?
Heel/Toe
35
60.34%
Neutral Coast
14
24.14%
Clutch Drag (no revmatching)
10.34%
E-brake FTW!
5.17%
Voters: 58. You may not vote on this poll
Revmatching? Anyone Do it?
Old Apr 6, 2008 | 10:08 PM
kptrulee's Avatar
Arrow Revmatching? Anyone Do it?
I dont know if this topic has been covered but I am just wondering what you guys/gals do when downshifting/braking/slowing down.
Let the discussions begin.......now
Old Apr 6, 2008 | 10:11 PM
cojaro's Avatar
I shift to N when I see a red light up ahead, and brake about halfway through. If it turns green before i come to a complete stop then I'll try my best to revmatch to the appropriate gear. I usually get within 250rpm of where it needs to be, so I'm getting better with time.
Old Apr 6, 2008 | 10:15 PM
smatts's Avatar
Honda Fit Forums Moderator
I do the thing where i let of the brake for a sec and tap the gas then back on brakes. thats not an option here?? i cant heel toe properly yet.
Old Apr 6, 2008 | 10:18 PM
solbrothers's Avatar
i can't heel toe with the tiny fit pedals :P :P. i do the clutch drag thing if i NEED to stop quick. otherwise i coast and somewhat brake.
it's easier/cheaper to replace pads/rotors than clutch
Old Apr 6, 2008 | 10:19 PM
Injundon's Avatar
for normal driving I just slap it Neutral and coast. When having fun I rev match. I can't heel-toe but I'm a size 10EEE. I have rediculously wide feet so I can use my right foot on the brake and throttle by just tlting it sideways. Works great in the fit since the pedals are close.
Old Apr 6, 2008 | 10:33 PM
cavie187's Avatar
I don't own a Fit so i don't find it appropriate to vote in the poll, but i will say that i usually (99%) just clutch drag.
But then again i have been known to do WOT no-lift-shifts from time to time also....
Old Apr 6, 2008 | 10:37 PM
Injundon's Avatar
most of the time WOT no clutch upshifts slow you down. It causes alot of lash in the drivetrain and makes your engine flop violently. stop doing it
Old Apr 6, 2008 | 10:38 PM
Fitsperfectly's Avatar
Heel Toe
Heel toe is the shit! it definetly wastes more gas though matching RPMs and heel toe everywhere. but its hard not to
Old Apr 6, 2008 | 10:42 PM
TOOL's Avatar
Is it possible to rev match a AT when using the paddles? lol
Or does it blip the throttle and rev match for you like the new GTR does lol? JK!
Tyler
Old Apr 6, 2008 | 10:45 PM
cavie187's Avatar
Oh, I understand. My PCM was flashed with a boost hold feature into the fuel mapping. Also have solid motor mounts and trans mounts with poly-bushings. Stage 3 twin-disk clutch.
Motor and trans don't flop, skip, or jump. Tires just give way to the torque.
BTW, No lift shifting is done with the accelerator staying stationary, not the clutch peddle. If I never lifted on the clutch i would definitely go slower.
Old Apr 6, 2008 | 10:48 PM
rev matching on an automatic? do not want!!
Old Apr 6, 2008 | 10:56 PM
kptrulee's Avatar
lol^^
sucks trying to heel/toe on a fit
wonder if anyone who has switched out the pedals to a different set has had any better luck with that setup
Old Apr 6, 2008 | 11:08 PM
jdjohnson9's Avatar
Im terrible at rev matching so i just play the "throw it in neutral" game most of the time. I have wide feet too so that doesnt help either.
Old Apr 6, 2008 | 11:22 PM
SD_MR_FIT's Avatar
i heel toe, especially when doing a canyon run.
rev matching i think helps alot...less jurking motion. i do it sometimes when im braking really hard.
yes.....
edit: i forgot to mention i do it everytime i down shift.
Old Apr 6, 2008 | 11:58 PM
Illusive's Avatar
With the Mugen pedals, I can do the side foot technique pretty good haha...no need to heel toe!
Old Apr 7, 2008 | 12:00 AM
PRDM's Avatar
Weren't you supposed to revmatch every time you downshift?
Old Apr 7, 2008 | 12:17 AM
Firebat666's Avatar
I heel toe it... not perfect but getting better im usually within 250-300 revs... but the electronic throttle makes it a tad difficult... but i am learning!
Old Apr 7, 2008 | 12:46 AM
sam21's Avatar
I only heel-toe when going up an on-ramp.It wastes to much gas to do it every time i turn,lol
Old Apr 7, 2008 | 01:34 AM
NA e Fit's Avatar
no heel toe for me... i like to rev match sometimes but it wastes gas... rev matching is cool when you have an exhaust... unfortunately i dont have one yet and thats why i dont do it often...
Old Apr 7, 2008 | 01:42 AM
Injundon's Avatar
It's not for sound, it's for stability into a corner and readily accessible power out of a corner.
