Center Caps For Enkei Rpf-1 15" Wheels?????
Old Apr 7, 2008 | 05:03 PM
YeeFit's Avatar
Does anyone know what, if any center caps fit onto the Enkei RPF-1 15" wheel on our cars???
Enkei does not sell center caps for the 15" RPF-1 wheel and they state that they aren't available either. I've read in some places that Konig Helium center caps, SSR Comp, and some Rota caps will work. I haven't seen any photos of this to prove it but I don't want to waste money trying several different ones before I get it right...
If you know which ones fit, have any pics, and know where I can get some that would be much appreciated.
Old Apr 7, 2008 | 07:43 PM
i wonder if the drag DR21's caps would fit...
Old Apr 15, 2008 | 01:29 PM
08FitSport's Avatar
Enkei Racing RPF1 Special Brilliant Coating
Here's one. Funny I was just looking to buy these wheels from Tire rack and it say none available but, if you type a search for Enkie RFP-1 this shows up. I wonder if the stock one fits.
Old Apr 15, 2008 | 01:48 PM
JDMchris.com's Avatar
I run THIS
centercaps only work on 16+ wheels. U cannot use them on 15
Old Apr 15, 2008 | 03:34 PM
Evotech8's Avatar
Try: good-win-racing.com
Mazda Performance Parts: Out BEST Miata Wheel....ENKEI RP-F1-15x7 41mm offset on SALE!
"Note that Enkei does not make a center cap for this size (15") but our KONIG HELIUM center caps will fit this wheel if you must have center caps (remove rear spring from Helium cap, insert main disc from the cap, and spray paint the small quarter-size "Konig" label before installing)."
The small quarter size konig label comes as a separate peel and "stick" on emblem, which can be left off the caps or painted if you wish.
Old Apr 17, 2008 | 06:38 PM
BlackCobra's Avatar
If you click on your link you can get hte RPF1's in gold but when you go on to TIRERACK.COM and do a search for it i cant find it in the RIM in GOLD...=(
NVM...tehy are only offered in 17" and 18"
Last edited by BlackCobra; Apr 17, 2008 at 06:40 PM. Reason: didnt read the TIRERACK web site thoroughly
Old May 22, 2008 | 03:18 AM
xorbe's Avatar
good-win-racing seems to be out of stock of konig helium center caps...
Old May 22, 2008 | 10:41 AM
Nerdsrock22's Avatar
Here is a pic of the Helium caps working on my car with custom machined centerpieces.
Old May 22, 2008 | 02:04 PM
paint the hubs like me? (duplicolor engine enamel paint).
Old May 22, 2008 | 02:05 PM
Old May 22, 2008 | 04:03 PM
08FitSport's Avatar
Once again Kenchan to the rescue!! I thought you had Drag 21s.
Old May 22, 2008 | 09:30 PM
can't hear can't hear.
Old May 23, 2008 | 02:17 AM
xorbe's Avatar
hey thanks for the photos in this thread, those are nice. mine should be here in a week.
about how much should it cost to move the tires over to the new rims and balance ya think?
Old May 23, 2008 | 07:22 AM
in my area it would cost anywhere from 15-30 each.
Old Jun 25, 2008 | 05:20 PM
xorbe's Avatar
Got them installed today finally! I was a little afraid that they might look a bit weird at stock ride height, but the 15" RPF1s look great -- probably because it's the same wheel size as stock. I definitely need to paint the inside area black (where the center caps would go) as suggested in this thread.
Hauling the stock Fit rims back upstairs, man those things are heavy!!
Old Jun 27, 2008 | 11:42 PM
Young Roids's Avatar
Since we are talking rpf1s I figured I will show mine even though I don't drive a fit. I did not get the center caps since they cost so much so I wonder if there are less expensive caps that would fit the 18 inch rpf1s
Old Jun 28, 2008 | 10:27 AM
i would worry about lowering your ms3 before caps...
Old Jun 28, 2008 | 12:53 PM
For some strange reason putting on the rpf1s really brought out the wheel gap even though I am running the stock rubber.
Old Jul 11, 2008 | 07:36 PM
xorbe's Avatar
Here are the Konig 15" Helium caps I just got via UPS today. Cheap plastic caps. Not sure how much massaging it will take to make them fit or stay yet, haven't tried a thing. Tomorrow morning. Need to find or make an alternative to the Konig circle sticker. 88 grams for all four caps and everything (plus the protective layer over the Konig logo that's not peeled away yet).
Old Jul 11, 2008 | 08:40 PM
that's because your stock wheels are +55mm offset and 6" width
while your F1's are probably +41mm offset and 7" width.
