Odyssey 2000 EGR system
Old Jul 17, 2005 | 08:56 PM
Leonard Caillouet
Guest
Posts: n/a
My engine check light came on and the ODB code indicates restricted EGR
flow. Looking briefly I see what appear to be sensors in the exhaust before
the cat con and in the cat con itself, but I do not see the EGR valve nor
the line to it. Anyone familiar with these enough to tell me if this is a
reasonably easy service job and where the EGR valve is located?
Also, and curious, the TCS light has intermittently come on when the engine
check light was on. Neither has come back on since I reset the codes and
have driven it several trips, including up to 60 mph with decel. several
times to get the EGR system check to operate. I wonder if maybe there is a
bad ground or transients in the system. I see complaints of erratic engine
check lights and unreliable ODB codes on Hondas of this era. Anyone have
some knowledge of this stuff?
Any recommendations for service manuals would be appreciated. I intend to
order the Honda manual, but if there are others that are more useful I'd
like to know.
The van has 80K miles on it. I am an electronics tech working on repairs at
the component level and have a DIY level of auto repair skill that is above
average.
Thanks,
Leonard
Old Jul 18, 2005 | 12:52 PM
Toby Cowger
Guest
Posts: n/a
Re: Odyssey 2000 EGR system
: My engine check light came on and the ODB code indicates restricted EGR
: flow. Looking briefly I see what appear to be sensors in the exhaust before
: the cat con and in the cat con itself, but I do not see the EGR valve nor
: the line to it. Anyone familiar with these enough to tell me if this is a
: reasonably easy service job and where the EGR valve is located?
: Also, and curious, the TCS light has intermittently come on when the engine
: check light was on. Neither has come back on since I reset the codes and
: have driven it several trips, including up to 60 mph with decel. several
: times to get the EGR system check to operate. I wonder if maybe there is a
: bad ground or transients in the system. I see complaints of erratic engine
: check lights and unreliable ODB codes on Hondas of this era. Anyone have
: some knowledge of this stuff?
: The van has 80K miles on it. I am an electronics tech working on repairs at
: the component level and have a DIY level of auto repair skill that is above
: average.
As well as replacing the EGR valve, you'll need to remove the intake manifold
and get all the carbon out of that, too. There is a kit available from Honda
that has a teflon coated pipe to fit into the EGR port to reduce the tendancy
for it to clog. It's about a half a day job for your first time.
The TCS light and check engine light are probably trying to tell you that
your transmission is failing. Get it into the dealer and they'll get you
a rebuilt one put in for free. These are covered out to 100k miles.
Unfortunately, your EGR system is only covered out to 80k miles. If you've
got a really good relationship with your dealer, they might let you slide
if you're just past 80k, otherwise, no.
Check out www.odyclub.com for a lot of info on both these common problems.
Old Jul 18, 2005 | 11:50 PM
chip
Guest
Posts: n/a
On 18 Jul 2005 10:31:05 -0600, Toby Cowger <tobyc@hpvcltc.vcd.hp.com>
>: average.
tcs light usually comes on with the egr code, by the way tcs doesn't
involve the tranny it gets all its info from the abs sensors.
Chip
Old Jul 19, 2005 | 08:45 AM
Leonard Caillouet
Guest
Posts: n/a
"chip" <hs4797@brevard.net> wrote in message
news:34rod1hp0kq56l8j1snn4t4cqcj9v4g2tt@4ax.com...
>>before
>>nor
>>a
>>engine
>>and
>>is a
>>engine
>>have
>>repairs at
>>above
>>: average.
>>manifold
>>Honda
>>tendancy
>>you've
> Chip
What causes the TCS light to come on with the EGR code?
Leonard
Old Jul 19, 2005 | 01:35 PM
Toby Cowger
Guest
Posts: n/a
:>: My engine check light came on and the ODB code indicates restricted EGR
:>: flow. Looking briefly I see what appear to be sensors in the exhaust before
:>: the cat con and in the cat con itself, but I do not see the EGR valve nor
:>: the line to it. Anyone familiar with these enough to tell me if this is a
:>: reasonably easy service job and where the EGR valve is located?
:>: Also, and curious, the TCS light has intermittently come on when the engine
:>: check light was on. Neither has come back on since I reset the codes and
:>: have driven it several trips, including up to 60 mph with decel. several
:>: times to get the EGR system check to operate. I wonder if maybe there is a
:>: bad ground or transients in the system. I see complaints of erratic engine
:>: check lights and unreliable ODB codes on Hondas of this era. Anyone have
:>: some knowledge of this stuff?
:>: The van has 80K miles on it. I am an electronics tech working on repairs at
:>: the component level and have a DIY level of auto repair skill that is above
:>: average.
:>As well as replacing the EGR valve, you'll need to remove the intake manifold
:>and get all the carbon out of that, too. There is a kit available from Honda
:>that has a teflon coated pipe to fit into the EGR port to reduce the tendancy
:>for it to clog. It's about a half a day job for your first time.
:>The TCS light and check engine light are probably trying to tell you that
:>your transmission is failing. Get it into the dealer and they'll get you
:>a rebuilt one put in for free. These are covered out to 100k miles.
:>Unfortunately, your EGR system is only covered out to 80k miles. If you've
:>got a really good relationship with your dealer, they might let you slide
:>if you're just past 80k, otherwise, no.
:>Check out www.odyclub.com for a lot of info on both these common problems.
: tcs light usually comes on with the egr code, by the way tcs doesn't
: involve the tranny it gets all its info from the abs sensors.
: Chip
Yup, Chip is right. TCS light comes on when the EGR system acts up.
I had the transmission, EGR, and cat conv problems all at the same time
and got my symptoms mixed up.
Let us know how your repairs go!
Old Jul 19, 2005 | 11:26 PM
chip
Guest
Posts: n/a
On 19 Jul 2005 11:10:05 -0600, Toby Cowger <tobyc@hpvcltc.vcd.hp.com>
>:>: average.
>: Chip
as i recall it's a PIFNH system fail code, the traction control
doesn't work because the engine is in open loop mode constantly. It's
just the way it is.
Chip
Old Jul 23, 2005 | 09:22 PM
Genboy
Guest
Posts: n/a
Agreed, the TCS comes on the same time as the check engine light for an
EGR flow problem, mainly because the TCS also uses vacuum pressure.
Old Jul 24, 2005 | 08:59 AM
Leonard Caillouet
Guest
Posts: n/a
I suspected the TCS might be using vacuum. If this is the case, however,
why would a clogged EGR system be the souce of the error. If there was a
vacuum loss, then a drop in EGR flow might be a symptom of the vacuum loss?
If the EGR flow is restricted, the vacuum should increase if everything else
stays the same, should it not? I assume that EGR flow is into the IM, not
the other way around. Maybe the TCS shuts down with any engine malfunction?
Is this stuff covered in the service manual or is there additional training
literature?
I have seen enough posts on various forums to make me wonder how reliable
the codes on Hondas of this era might be. I work on electonics and know how
something as simple as ground integrity or a little noise can affect a data
bus or corrupt an EEPROM. I am wondering if there is a problem at all. At
about the same time that the engine and TCS lights came on I had a strange
control problem in the AC. The modes would not switch and it came on in the
defrost mode instead of the normal auto mode. None of the problems have
occurred again. I'll plot the data on the fuel economy today and see if
there are any changes there, but an initial look indicates no problem.
Leonard
"Genboy" <genboyx@yahoo.com> wrote in message
news:1122167359.560499.17590@o13g2000cwo.googlegro ups.com...
Honhel
Jul 27, 2015 03:05 PM
Myxalplyx
Dec 12, 2014 02:18 PM
MNfit
Jan 9, 2010 09:24 PM
Lamak
Mar 15, 2009 03:24 AM
hisame2332
Sep 6, 2005 02:53 PM
