Looking for JDM all clear LED tails - Anyone know where
Old Apr 8, 2008 | 04:52 PM
Tiffany's Avatar
I am looking for a reputable seller for a set of JDM tails OEM version.
anyone know a dealer that stock these.
any does anyone know if the sockets have to be modifyed
someon said they go in crooked only way
thanks for the help
Tiffany
Old Apr 8, 2008 | 04:54 PM
JDMchris.com's Avatar
I run THIS
One of the sockets doesnt sit in right, but it holds enough to where it wont fall out. You have to lengthen the wires for the JDM lights as well.
Old Apr 8, 2008 | 05:01 PM
Tiffany's Avatar
what wrong with the socket, can you get the ones that do sit OK
Old Apr 8, 2008 | 05:50 PM
I run THIS
all of the JDM sockets are different than the USDM ones... You will have to modify ANY set of JDM lights if you want them to fit 100% correctly.
Old Apr 8, 2008 | 07:24 PM
Tiffany's Avatar
how do I modify them. I am good at thing like this
tiffany
Old Apr 8, 2008 | 07:34 PM
I run THIS
A dremel to either the socket itself or the plug.
Old Apr 8, 2008 | 08:38 PM
Tiffany's Avatar
Thanks, I got a dremel. I guess it like a puzzle. make it fit.
cut the notch out.
now where do I get jdm honda oem ones in all clear...anyone
Old Apr 11, 2008 | 01:41 AM
wrx112's Avatar
I can get a set PM me. Cheers
-Mike
Old Apr 11, 2008 | 03:21 AM
s0x's Avatar
s0x
hmmm
i think rickygoshdarn has a set for sale also ive installed more than one pair of these without extending wires chris is right you should probably extend them but if your willing to pop out a few clips you dont need to extend anything id rather break plastic clips than cut into wires.
Old Apr 11, 2008 | 08:25 AM
Tiffany's Avatar
Me too, I plan on taking the back apart to extend the harness.
I wonder why someone does not sell a harness extention Male/female plug.
I would buy it.
what panels do I remove//
anyone one have any pictures, if not I will do a DIY
Old Apr 11, 2008 | 03:44 PM
s0x's Avatar
s0x
I would buy it.
basically your doing this. there is a clip that is taped! to the side on th driver side you cut that tape and pull a little bit dont be scared of breaking things just pull damnit i think there is one you CANT SEE too a little lower just reach for it. the one thats taped is in plain view...on the pasanger side all you really have to do is this.. the socket that you would plug the wiring into for the LED board is on a little track on the headlight pull it off the track it wont break or anthing its ment to come off. when you pull that off it makes enough room :P the end lol.
Old Apr 11, 2008 | 04:04 PM
Tiffany's Avatar
Thanks, NO CUTTING OHHHH GREAT,
what about the socket thingy, can i JUST get JDM one that does fit.
and I found a set today, should have them next week. I have a storm and got the red/clear jdm. A lot have the smoked and I want to be different.
Old Apr 11, 2008 | 04:13 PM
s0x's Avatar
s0x
you can just make it work take the fat part and put it in te fat part and fidgit with it it will sit in there eventually you dont need anything special if you REALLY want you can cut it to make it almost perfect but its up to you i just crammed mine in there it looks perfect and hasnt falledn out.
Old Apr 11, 2008 | 04:24 PM
Tiffany's Avatar
i am pickly, cut the light or the socket thingy
hey, thanks for all the advice... love my fit too
stalonehong
California - Bay Area Community
Jun 7, 2009 01:40 AM
stalonehong
May 22, 2009 02:54 PM
stalonehong
May 11, 2009 02:51 AM
AtticusFit
Apr 24, 2009 11:53 PM
Padraic
Dec 1, 2008 07:53 PM
