Double Your Gas Mileage?
Old Apr 8, 2008 | 07:20 PM
DogSlobba's Avatar
This sounds too good to be true. Surely this will damage your engine?
Double Your Gas Mileage! 2X Video - Metacafe
Old Apr 8, 2008 | 07:33 PM
Kuturagi's Avatar
That would be sweet! I dont know never tried it lol
Old Apr 8, 2008 | 07:35 PM
cojaro's Avatar
I've heard the acetone is a myth. Everything else he does works, as far as I know.
I was more interested in the "Beaver Cam" vid :-D
Old Apr 8, 2008 | 07:44 PM
osborne's Avatar
You know the saying. IF IT IS SOUNDS TO GOOD TO BE TRUE...
Acetone Deaf
Claim: Adding acetone to gasoline in an effort to improve gas mileage is a good idea.
Status: False.
Example: [Collected via e-mail, 2007]
I have heard that adding small amounts of pure acetone to your gas can increase car mileage between 15% and 30%. Is this true? I did some further research and it appears that it enables more of the gas to burn thus increasing mileage. Are there any concerns for the engine? Any input would be appreciated.
Origins: As fuel prices go up, so does interest in various products and additives said to improve gas mileage. One of these is acetone, a widely-available solvent better known to most of us as nail polish remover. According to some, adding a few ounces of this chemical compound to a tank of gasoline will dramatically increase mileage, supposedly by assisting in the vaporization of fuel.
Although various claims have been made about acetone improving gas mileage by 25% or 30%, those avowals never seem to hold up to independent scrutiny: properly controlled experiments
designed to measure the ballyhooed improvement fail to recognize any significant change.
Curious motorists working in less controlled settings do at times seem to note an acetone-assisted improvement, yet their results are likely better chalked up to careless measurement or miscalculation, as their findings can't be reproduced in the lab. Confusing matters further is the issue that determining the effect of anything upon gasoline mileage is a bit more difficult to work out than it would seem, beause so many different factors can affect the results. The same amount of fuel will produce different gas mileages on different days, depending upon variables such as the type of automobile, the weather conditions, whether the car's air conditioning was running, how fast the vehicle was driven, etc. Eliminating the effects of each of these factors from the computation is generally beyond the abilities of the average car owner with a passing interest in knowing how many miles to the gallon his pride and joy is getting.
Were the decision of adding or not adding acetone to one's fuel tank merely a question of whether the practice boosted gasoline performance, that would be one thing, but unfortunately there are other issues to consider, such as the harm that the solvent can work on vehicles. Acetone is corrosive, which means it can eat away at rubber components such as gaskets and O-rings — a particularly bad result for cars with rubber hoses in their fuel lines.
Acetone will also eat the paint off a car. As Tom of Car Talk noted in January 2006: Here's our final reason not to use [acetone]: It dissolves paint. So if you slip and spill a little bit outside your fuel filler door, you'll have a nice, unpainted line running down to the bottom edge of your rear quarter panel. When we see you drive by, we'll know you didn't take our advice!
Barbara "the telltale trail" Mikkelson
Additional information:
Good, Better, Best: How to Improve Gas Mileage
(Federal Trade Commission)
Last updated: 13 June 2007
Old Apr 9, 2008 | 02:23 AM
Snap Fit's Avatar
Its bunk! And if I remember correctly it has been shown to be bunk many times, from newspaper articles to the news to even TV shows.
But did anyone see the cat jump out of the trunk in the vid?!?!?!?!?!?!!!!
when he said "I had alot of stuff that didn't need to be in there"
so -1 cat=+1 mpg! excellent! So is it like +5 mpg if I get rid of the body in my trunk/hatch?????
(and yes I know of the general 200lb rule...I am just making a funny)
Old Apr 9, 2008 | 02:43 AM
Gordio's Avatar
Yea too good to be true. Acetone is so cheap. If this worked, it would be mandatory.
Old Apr 9, 2008 | 10:51 AM
FITrunner's Avatar
This gets you the best mpg.
Old Apr 9, 2008 | 03:29 PM
DogSlobba's Avatar
maybe fitrunner, but if you're anything like your avatar, you won't get very far!
yeah, i'm aways suspicious of these 'increase your mileage' schemes. People have tried everything from magnets to who knows what. But if anything actually made a noticeable difference, the idea would spread like wildfire.
still, i thought it would be worth sharing cos the author seemed so convinced of his discovery.
Old Apr 9, 2008 | 04:01 PM
FITrunner's Avatar
Bah! I've cut back to one doughnut a day. Workin on it hehe.
Old Apr 10, 2008 | 02:21 AM
claymore's Avatar
Even Mythbusters did the acetone myth and IT'S BUSTED.
gguest
Jun 24, 2019 05:19 PM
Mzzchief
Jul 23, 2010 10:27 PM
kimdizzle
Feb 5, 2010 05:46 AM
Sugarphreak
Jun 7, 2009 11:46 AM
