What is a power steering grease - where to get one?
Old Jul 20, 2005 | 10:30 AM
Sam Nickaby
Guest
Posts: n/a
I am rebuilding a steering gearbox that was damaged after an accident. I'd
posted earlier topic here http://snipurl.com/gdhs. I have all the seals and
o-rings that I will install. The service manual requires that I use a power
steering grease but the dealer does not know where to get this grease. What
is a compatible grease I can use for the steering gearbox?
Thanks
Old Jul 20, 2005 | 11:30 AM
marks542004@yahoo.com
Guest
Posts: n/a
Re: What is a power steering grease - where to get one?
I usually solve these problems by a visit to the local auto parts
store. They usually look it up for me in the maintenance manuals.
I am surprised the service manual does not give the specification or
original part number.
Old Jul 20, 2005 | 12:30 PM
butch burton
Guest
Posts: n/a
my 97 accord shop manual from Helms only mentions putting silicone
grease on the boot end of the rack grooves. In several other places
they say to apply grease and use the symbol for the typical hand grease
gun for zerk joints. Also in a couple of places they say to apply
honda PSF to the surfaces.
I hope you have the Helms manual - it is really complete and this is a
complex system.
good luck
Old Jul 20, 2005 | 03:32 PM
Comboverfish
Guest
Posts: n/a
> Thanks
You can simply coat the seals with Honda P/S fluid - since that is what
they will see for the rest of their lives. Dunk them in a container of
P/S fluid immediately before installation to ensure they stay wet.
You could also use vaseline as an assembly lube; it will dissolve in
the P/S fluid and cause no problem.
Do you have the cone shaped installation tool to stretch the seals onto
the rack end pistons? If not, stretch the seals gently and evenly with
your fingers before *carefully* placing them over the piston.
Disregard if you have an aftermarket seal kit with scarf-cut seals.
Keep in mind that there is a way you can get the high and low pressure
pipes crossed on your Accord. It's not easy, but the same people who
can put in an 1157 bulb backwards can also manage this feat, so be
careful.
Toyota MDT in MO
Old Jul 25, 2005 | 09:06 AM
Sam Nickaby
Guest
Posts: n/a
Help. I have one extra O-ring left unused. There is no where to install it.
Either this is the first time the Helm service manual has made a mistake
or I am not being thorough. I can clearly see that the instructions did not
mention this O-ring but it's drawn on the cover page. Here, take a look.
http://img335.imageshack.us/img335/6964/oring4fj.gif
Is this a print error or is this O-ring suppose to be installed somewhere?
BTW, Thanks for the great advices but still unable to find steering/silicone
grease. I've already completed my assembly (forgot about Vaseline)
instead, I used its original grease.
Old Jul 25, 2005 | 10:39 PM
jim beam
Guest
Posts: n/a
the old grease should be fine. do /not/ use vaseline - it's petroleum
based.
silicone greases are stocked at many online industrial supply stores and
electrical supply stores. a good mechanical grade silicone is "dow
corning 33", but i don't know for sure it's right for this application
because it contains a lithium soap. if going the electrical supply
route, look for "high dielectric" grease. silicone is usually there.
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:Z6ydnQEN78KfCnjfRVn-tg@speakeasy.net:
> Sam Nickaby wrote:
>>>accident. I'd posted earlier topic here http://snipurl.com/gdhs. I
>>>have all the seals and o-rings that I will install. The service
>>>manual requires that I use a power steering grease but the dealer
>>>does not know where to get this grease. What is a compatible grease I
>> install it. Either this is the first time the Helm service manual has
>> made a mistake or I am not being thorough. I can clearly see that the
>> instructions did not mention this O-ring but it's drawn on the cover
>> somewhere?
>> steering/silicone grease. I've already completed my assembly (forgot
>> about Vaseline) instead, I used its original grease.
> based.
> and electrical supply stores. a good mechanical grade silicone is
> "dow corning 33", but i don't know for sure it's right for this
> application because it contains a lithium soap. if going the
> electrical supply route, look for "high dielectric" grease. silicone
> is usually there.
Zip Slip is good.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 26, 2005 | 08:59 PM
Comboverfish
Guest
Posts: n/a
> based.
Egad! It might mix with the hydraulic oil (power steering fluid)...
which is also petroleum based. If rack seals were inherently
intolerant to petroleum, they would never last in P/S fluid either.
Vaseline can be used much the same way it has been used forever in
automatic trans rebuilds. It's not necessary if you are careful with
the end seals or use a cone installation tool, but certainly OK. It
melts away at low temps and dissipates in the system much better and
safer than a run-of-the-mill bearing type grease.
Toyota MDT in MO
Old Jul 27, 2005 | 12:33 AM
jim beam
Guest
Posts: n/a
Comboverfish wrote:
>>based.
> Toyota MDT in MO
well, honda power steering fluid is /not/ compatible with other power
steering fluids - it wrecks seals. i don't know for sure what the
situation is, but if it were a silicone oil rather than a mineral oil,
that could easily account for the manufacturer spec for silicone grease
and would /definitely/ rule out compatibility with vaseline.
Old Jul 27, 2005 | 11:30 AM
Comboverfish
Guest
Posts: n/a
That's true.
It is a mineral oil based fluid. Most likely the different additive
package is what causes seal incompatibility when non Honda fluid is
used.
I think this whole silicone grease conversation was in reference to the
rack boots. Probably something to help keep the rubber soft over the
years, or possibly to assist in installing the new boots onto the rack
housing -- or to allow them to spin freely vs. twist during toe
adjustment. I couldn't make out exactly what the OP was refering to, I
was just offering a suggestion to keep the very fragile end seals from
getting nicked during installation.
Toyota MDT in MO
Old Aug 2, 2005 | 07:37 PM
Sam Nickaby
Guest
Posts: n/a
> Toyota MDT in MO
Vaseline might help to slip the rack into the seal because I didn't use a
cone. It may also help to install other areas. I cringe every time it slip the
end seals pass the rack since the PSF didn't help. Your advice regarding
stretching the seals onto the rack end pistons with our fingers help
because the dealer won't sell the cone installer.
Here are some helpful advices in case anyone needs to fix a rack leak. The
most essential parts are the Genuine parts, picture 47 part number 91354-
SA5-952 O-RING (24.5X2) $0.29 and picture 23 53633-SE0-953
(requires two gasket) CYLINDER END seal $0.88 or 88 cents each. Or
buy the gearbox at $751.00. The insurance agency valued my salvage Honda
for $250 after the accident so I had to fix it.
The service manual requires that we replace all the seals, but I could get
away with only four. It's unjustified to replace only four seals or
o-rings.
Parts.
http://www.slhondaparts.com/images/PCI/13SE00/010/9.jpg
Mirror site.
http://www.yourimg.com/?img=05/214/17/rack.jpg
Best deal store
shawnshank
Jun 9, 2017 05:07 PM
dcmcelreath
Oct 8, 2015 11:11 PM
FrogDaddy
Jun 28, 2009 01:59 AM
willy65000
Feb 18, 2009 11:07 PM
disallow
May 4, 2005 04:44 PM
