Have any of you had issues with toe?
Old Apr 14, 2008 | 03:01 PM
Zhu Tou's Avatar
I spent a fortune to have my '97 Civic lowered properly, an act seeminly lacking in the aftermarket tuning community.
After the Tein springs and dampers went in, they were quickly followed by front and rear camber kits and a rear toe-adjustment kit. After a bit of hassle with alignments, all four wheels on my car point straight and the tires are in full contact with the ground.
I want to do the same when I purchase the '09 Fit.
I've managed to find front and rear camber kits for the current Fit, but not toe-adjustment kits. Do these exist? Do you Fit owners experience problems with rear toe?
Old Apr 14, 2008 | 08:55 PM
billmus86's Avatar
My Lips Bigger!
call the toe truck
Old Apr 15, 2008 | 12:34 AM
SD_MR_FIT's Avatar
i just deal with it.
i heard shims would be a great way to fix it. but i dont get how that would work for the toe.
mine is within specs but its pushing the limits
Old Apr 15, 2008 | 12:38 AM
Burbio's Avatar
since i dropped my car on eibachs and put 17s on, i've been bouncing all over the lane. even with an alignment. i need to go back and have 'em do it again. like, when i get above 80 or 85, it's so hard to control. stock was straight as an arrow. is that even what you're talking about?
Old Apr 15, 2008 | 08:22 AM
i have some alignment "after" measurements in my newbs intro page somewhere near the
end.
the rear toe-in is severe after the drop. only way to adjust is by
using shims under the brake drum...which i haven't tried yet.
Old Apr 15, 2008 | 04:37 PM
mahout's Avatar
Front Toe is adjusted by the tie rods and there is considerable range. If you ran out of front toe adjustment you have lowered way too much.
Rear toe is adjusted by shims between the axle plate and hub backplate. It is a job for EXPERTS however, not your local shop.
Old Apr 15, 2008 | 04:47 PM
SD_MR_FIT's Avatar
does that shim trick mess with the rear abs though?
Old Apr 15, 2008 | 05:18 PM
fit_love's Avatar
i had problems with toe, the place i took it to first wouldnt even align my car, so i took it somewhere else and they got it as good as they could without a kit, and i gotta say my ride is perfectly straight. i just deal with it. not really a big deal, just a tiny bit of uneven wear in the back, nothing i cant handle.
Old Apr 16, 2008 | 11:22 AM
Zhu Tou's Avatar
I'm going to disagree and claim that toe-in is a big deal.
Besides having to spend money on new tires more often, toe-in results in poorer traction, poorer braking and poorer stability overall. I'm by no means a suspension expert, but I am sure that toe-in puts unnecessary stress on other suspension components.
I hope that when the '09 is released, someone out there will produce a toe-adjustment kit for it so that hassles with shims can be avoided. I currently have an SRR kit on my Civic, and I see that Tein also manufacturers kits for select models.
We all make modifications to our cars to increase their performance (well, many are just concerned with looking good) but sacrificing safety is not on my list.
Old Apr 19, 2008 | 01:59 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
one of the smartest things i've read all day.
Old Apr 19, 2008 | 02:44 PM
mahout's Avatar
Since rear toe adjustment requires considerable design changes on a Fit Honda is not likely to do it.
I'm with you tho' toe IS a big deal, front or rear.
Old Apr 19, 2008 | 02:47 PM
mahout's Avatar
end.
Shims go between rear backplate and axle plate. Putting shims behind brake drum won't help. You have to change the angle of the spindle.
KeithDigital
Feb 1, 2012 11:42 AM
Stacey444
Nov 16, 2011 09:37 AM
c_mack9
23
May 8, 2008 12:01 AM
coupdetat
Feb 20, 2008 07:57 PM
cheebz
23
Jan 7, 2008 11:33 AM
