Rear suspension is off!
Old Jul 22, 2005 | 10:45 PM
TeGGeR®
Guest
Posts: n/a
http://www.tegger.com/hondafaq/misc/...suspension.jpg
I'm off to the machine shop tomorrow to get the bushings pressed out.
This has easily been the most frightening job I've ever attempted, mostly
due to the amount of disassembly required. Ain't nothin' left of that back
end.
TeGGeR®
chip
Guest
Posts: n/a
Re: Rear suspension is off!
>end.
beat them out with a hammer, we don't press them at the shop. I've
done them on the car.
Chip
Old Jul 23, 2005 | 01:32 AM
jim beam
Guest
Posts: n/a
> end.
well, you're committed now! seriously, it's a very worthwhile job. you
going to post pics of the old bushings?
Old Jul 23, 2005 | 09:22 PM
TeGGeR®
Guest
Posts: n/a
chip <hs4797@brevard.net> wrote in
news:5s93e1tt77ropc8drfsj4lnbf9kljfgi8i@4ax.com:
>>mostly due to the amount of disassembly required. Ain't nothin' left
>>of that back end.
> Chip
Even the shop had some trouble due to the rust. I would have been stuck had
I tried that method.
Also, four bolts took a big air wrench to get loose, and one never did come
out and needed to be ground off. Unfortunately, the shop also managed to
knock off the nut (on the trailing arm) for the bolt on the outer end of
the lower control arm. Now I have to get a new Grade-10 bolt and nut to fit
that area. I've temporarily got a 10x70mm Grade-8 bolt and Nyloc nut from
Home Depot in there just so I can button everything back up.
And one of the bolts for the upper arm on the one side feels like it wants
to cross-thread, and of course the stores are now closed and I don't have
the correct size tap to chase the threads with.
TeGGeR®
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:S8mdnW-Tt8jiVHzfRVn-sQ@speakeasy.net:
>> of that back end.
> you going to post pics of the old bushings?
It's all back in now, with a couple of headaches (see my reply to chip).
Just have to put the brakes back together and do the roll-around bit before
I set the alignment back to what I measured before I started, and tighten
everythibg back up.
I notice almost all the bolts have those little blue Nylon inserts in them.
Now I'm wondering if I should get all new bolts or just use Loctite.
The Red Loctite says it needs 450F of heat to be able to remove them once
they've set, which makes me kinda leery of using it.
And yes, I saved the old bushings. They look pretty gross. Both the big
ones were almost severed on the top rubber leg.
TeGGeR®
jim beam
Guest
Posts: n/a
>>>of that back end.
> everythibg back up.
i've not bothered & i can't say i've had any problems. if you're going
to use loctite, /don't/ use high strength - the fact that the nylon
inserts are so small indicates there's not much loosening going on.
blue should do you.
jim beam
Guest
Posts: n/a
>>>of that back end.
>> Chip
try not to chase if you can avoid it. if you jack the arm up into
position and use the right bolt, the one with the rounded end, you
should be able to get it in ok. the jacking bit is the key. one time,
i even dropped the two big pivot bolts back off to make it easier to get
a difficult top arm in. once located & loosely bolted, getting the
pivot bolts back was fairly straight forward. do the one with the
elongated slot first.
jim beam
Guest
Posts: n/a
>>>> of that back end.
>> before I set the alignment back to what I measured before I started,
>> and tighten everythibg back up.
forgot to say, you'll still probably need an alignment. no matter how
hard you try to keep everything "just so", it never is, and the
alignment for these rears needs to be really dead-on to be good.
>> them. Now I'm wondering if I should get all new bolts or just use
>> Loctite.
> inserts are so small indicates there's not much loosening going on. blue
> should do you.
>> once they've set, which makes me kinda leery of using it.
>> big ones were almost severed on the top rubber leg.
TeGGeR®
Guest
Posts: n/a
news:itCdnScJr7mZeX_fRVn-tA@speakeasy.net:
> time, i even dropped the two big pivot bolts back off to make it
> easier to get a difficult top arm in. once located & loosely bolted,
> getting the pivot bolts back was fairly straight forward. do the one
> with the elongated slot first.
That's not the problem. I have a clear view into the hole (left side, rear
slotted hole) and it's a totally clear path into the hole. I can get it to
take the first two threads or so, but then it binds, like it does when it
seats. Or cross-threads.
The other bolt is fully home.
Just settled the suspension. Ride height is back where it should be. I'm
off to tighten and align.
TeGGeR®
TeGGeR®
Guest
Posts: n/a
news:itCdnSYJr7kIeX_fRVn-tA@speakeasy.net:
Sorta wondering about that.
The way I'm measuring it, I'm getting 9 1/16" on the left and 8 31/32" on
the right (doesn't matter now how I'm getting that). The left tire has
excess wear on the outer tread.
I'll set both to as close to 8 31/32" as I can, then get a proper
alignment.
TeGGeR®
TeGGeR®
Guest
Posts: n/a
By the way, I tried a bolt from the other side and the same thing happened,
so I'm sure there's a burr in there somewhere.
TeGGeR®
Old Jul 23, 2005 | 10:44 PM
TeGGeR®
Guest
Posts: n/a
Weird...
No matter where I lever the trailing arm before tightening the compensator
arm, the toe does not change. It's exactly the same as what I measured
before I took everything apart.
That position is what they return to naturally when I drive onto the
newspaper. (I put a thin section of newspaper under the tires so they could
pivot more easily.)
TeGGeR®
jim beam
Guest
Posts: n/a
TeGGeR® wrote:
> Weird...
> pivot more easily.)
it does change. if you watch the tech in the alignment shop, the gauges
show it changing as they make their adjustments. but they're real
small, and as you'll find out driving to & from the alignment shop, they
make an interesting difference.
TeGGeR®
Guest
Posts: n/a
news:Af2dnXM8arlVan_fRVn-rQ@speakeasy.net:
> TeGGeR® wrote:
>> Weird...
>> compensator arm, the toe does not change. It's exactly the same as
>> what I measured before I took everything apart.
>> could pivot more easily.)
> gauges show it changing as they make their adjustments. but they're
> real small, and as you'll find out driving to & from the alignment
> shop, they make an interesting difference.
I'll bet.
A guy I used to work with lowered his Chev S10. He said the entire way to
the alignment shop the tires squealed like a banshee. Gotta phone the
alignment people Monday.
It's going to be interesting trying to find a metric tap. NOBODY has those
last time I checked except the specialty industrial suppply places. I
notice all the bolts are 10x1.25mm. What's the closest Imperial tap size to
that?
TeGGeR®
TeGGeR®
Guest
Posts: n/a
> TeGGeR® wrote:
>> Weird...
D'oh!
I just realized my mistake!!!!!
I'm taking the measurements at the BACK of the tire. The reason was that I
couldn't find a good datum point at the front!!
Damn!
Now there's NO WAY I'm going to get the alignment even /close/ myself.
TeGGeR®
Old Jul 23, 2005 | 11:38 PM
jim beam
Guest
Posts: n/a
>>TeGGeR® wrote:
>>>Weird...
> I'll bet.
> that?
mcmaster.com has M10 x 1.25
TeGGeR®
Jul 7, 2005 01:26 AM
TeGGeR®
Jul 6, 2005 10:06 AM
TeGGeR®
Jun 3, 2005 01:06 AM
Shawn McClelland
May 4, 2005 04:44 PM
Chris
May 4, 2005 11:16 AM
