99 Accord Water Pump
Old Jul 24, 2005 | 08:59 AM
lcmon
Guest
Posts: n/a
Hi,
99 Accord V6 3.0L
To replaced the water pump how many o-rings/gaskets
do I've to replace ? Are they come with the new pump ?
How many tensioner & idler are there for the Timing Belt?
One more thing on the Fan Belt Tensioner can I get&replace
just the little bearing on the pully ? What's the part#?
Thanks in advance
LC
Old Jul 28, 2005 | 01:31 AM
johngdole@hotmail.com
Guest
Posts: n/a
Re: 99 Accord Water Pump
I have a preference for Gates products.
http://www.gates.com/brochure.cfm?br...cation_id=3487
The car has one pulley and one tensioner. The hydraulic unit that
pushes on the tensioner pulley is not part of the Gates Timing Kit.
Don't know if it should be replaced.
The waterpump should come with an o-ring. Do check when you pick it up.
I always like to use the NAPA *NEW pumps*. No reman pumps for me.
Yes, you can get the pulley only for the serpentine belt tensioner like
about 40-50% the cost of the entire auto tensioner.
Also change out the oil seals while you are at it.
Check Gates' online catalog.
pch
Aug 26, 2005 12:55 AM
wpapps@verizon.net
Aug 8, 2005 07:30 PM
Ray
Jun 30, 2005 12:43 AM
PK
May 4, 2005 11:16 AM
mpet500
