91 Accord engine stall
Old Jul 24, 2005 | 10:44 AM
Fijoy George
Guest
Posts: n/a
Hi all,
I bought a used 1991 Honda Accord DX Coupe recently, and it has been giving
me problems. Sometimes the engine would stall while driving, and I have to
restart the car. This happens both at signals and on the highway. It also
sometimes would not start after parking somewhere.
I gather this is a common problem with Accords, and it is usually caused by
a faulty ignition system or fuel pump. Is there anything cheap that I can do
to narrow down the cause to just one component? This is my first car, I know
practically nothing about car repairing. Is it possible for me to do some
diagnosis by myself, perhaps by looking at some reference book?
Thanks
Fijoy
Old Jul 24, 2005 | 11:36 AM
motsco_ _
Guest
Posts: n/a
Re: 91 Accord engine stall
Fijoy George wrote:
> Hi all,
> Thanks
> Fijoy
Forget the fuel pump for now. The MAIN RELAY causes it to not start when
it's warm under the dash. Smack the dash with the key in position II, it
will start until next time. The failed ignition switch stops it dead in
traffic / on the highway. Resolder the relay, get the ignition switch
replaced before you get killed.
'Curly'
Old Jul 24, 2005 | 12:31 PM
TeGGeR®
Guest
Posts: n/a
"Fijoy George" <tofijoy@yahoo.co.in> wrote in
news:dc07h9$l00$1@mailhub227.itcs.purdue.edu:
> Hi all,
> giving me problems. Sometimes the engine would stall while driving,
> and I have to restart the car. This happens both at signals and on the
> highway. It also sometimes would not start after parking somewhere.
Might be the Main Relay or ignition switch, as Curly says.
http://www.tegger.com/hondafaq/faq.html#startrun
> caused by a faulty ignition system or fuel pump.
An *old* ignition system, yes. The fuel pump would not cause this.
Is there anything
> cheap that I can do to narrow down the cause to just one component?
> This is my first car, I know practically nothing about car repairing.
> Is it possible for me to do some diagnosis by myself, perhaps by
Clean the throttle body and EACV. Reset idle speed correctly.
Replace the plugs, wires, rotor and distributor cap. With OEM. A weak spark
can cause stalling.
TeGGeR®
Old Jul 24, 2005 | 11:53 PM
SoCalMike
Guest
Posts: n/a
Fijoy George wrote:
> Hi all,
ignition switch behind the lock cylinder
main relay
its rarely the fuel pump... id swap the first 2 out just because theyre
due.
wannadoitmyself
Aug 29, 2005 01:31 AM
kathleen williamson
Aug 15, 2005 11:30 PM
Spoilaz via CarKB.com
Aug 9, 2005 10:30 PM
Randy MacKenna
Jul 1, 2005 12:32 AM
punkyw
May 15, 2005 07:30 PM
