Someone shed some light on this please
Old Apr 22, 2008 | 08:50 PM
gmane's Avatar
I've got progress spring installed w/ 195/50/15's I know that one side is higher than the other by nature but when i'm coasting the ride is very "bouncy"? like if i just go 30 - 40mph in nuetral and coast i can feel slight "springiness" even on flat roads.. what do you guys think it could be? I went to the dealer and had them tighten all my bolts after i did the spring install so that rules that out. The springs make no creeks, squeeks or bump noises when going over bumps... Its very annoying and i'm wondering if just the lower profile tire and the fact that the springs are stiffer is causing me to feel what i wasn't able to feel with stock springs and stock tires?
How would i know if there is a problem with the axel/bearings?
Any help would be greatly appreciated.
Thanks guys
Old Apr 22, 2008 | 09:03 PM
cojaro's Avatar
The tires are as much a part of your suspension as the springs are. Lower profile tires have less sidewall and as a result can't compress as much as a tire with a larger sidewall. So, basically, they're "stiffer" than stock tires, so you'll feel more bumps and want-not.
SD_MR_FIT's Avatar
uh i guess your springs are stiff. but thats normal to feel every flaw on the road.
its a combination of both. your tires and springs. but its mainly your springs.
dont worry its normal
Old Apr 22, 2008 | 09:06 PM
gmane's Avatar
arrgghh.. just doesn't seem normal to me, i can't remember my other hondas feeling like this.. even on flat surface or mostly flat surface its just a ever so slight annoying bounce or on an medium acceleration it almost feels like slight wheel hop? if that makes sense..
Thanks for the replies so far...
Old Apr 22, 2008 | 09:34 PM
wheels out of balance? wheels not centered correctly onto the hub?
is it a vibration? are your lugs torqued correctly? do you have a flat
spot on your tire?
are your tires pressure around 32-34 range while cold?
wat offset are your running?
describe this springie feel in more detail. im not sure wat you mean.
Old Apr 22, 2008 | 09:40 PM
gmane's Avatar
spot on your tire?
Lugs are tightened atleast i think they are... tires are brand new less than 100 miles on them so i doubt there is a flat spot.. rims and tires are brand new came balanced from JLBmotorsports (they have the balancing weights on them). I was thinking it could be an off balanced wheel also.. if i had to describe it i would say it feels as if something is off balanced or out of sync maybe.. like lets say you had one rim that wasn't tightened enough so it would give a slight wobble which would give you vibration and in my case a springy/bouncy feeling but very subtle.. enough to feel it thou as i said when slowing to a stop the bounce gets progressively more noticeable.. i dont know the tire pressure when its cold i believe it is around 32 - 34 like you said because i did check the pressure today but that was after a 10 - 15minute drive.. one tire had low pressure but i pumped it up and i still feel the bounce.. sorry if the description sucks but im not sure howelse to describe it..
mahout's Avatar
The lower profile and stiffer springs do indeed increase the 'response' of your Fit to road surface irregularities. Thats the reason the hipo Ferrari, BMW, etc go with lower stance and lower profile tires. There's less angle between true path and steered path when you turn, too. Most of that extra spring stiffness is due to excessive lowering (2" or more) and to the light weight of the FIT (2500#). Just goes with the territory.
Old Apr 22, 2008 | 09:48 PM
try moving your passenger front tire to the rear and your rear to the
front. take a test drive.
if it improves, you got a wheel that is out of balance (or not true...).
If no change, do the driver side fron tire to the rear and your rear to
the front. take a test drive.
process of elimination.
Old Apr 22, 2008 | 10:04 PM
gmane's Avatar
Thanks all else fails i'm gonna put the stocks back on and just see if i feel it then i know its not the wheels.. and could be something else?
Old Apr 22, 2008 | 11:13 PM
did you pop the cv joint when you installed the fronts? might be out of
alignment on the cv joint? not sure wat else it could be, given that you
installed the springs correctly. the sus on this car is so darn simple...
Old Apr 22, 2008 | 11:38 PM
gmane's Avatar
I popped something out.. but i don't get a clunking sound or anything.. how would i know if the cv joint is out? and how the heck do i realign it if it is..
Old Apr 23, 2008 | 08:50 AM
it should only go in one way so if you assembled it back together
it should be fine. the last 10yrs+ working on honda's ive never
had a cv pop out on me hahaha. it would be a twist push,
twist push, until it pops back in.
try eliminating your wheels/tires first.
Old Apr 23, 2008 | 10:15 AM
gmane's Avatar
Thumbs up
Yeah i've been driving for atleast a week now since i changed the springs/rims so i figure if something wasnt' in right i should know by now? I'm gonna try swapping around the wheels.
Thanks again
Old Apr 23, 2008 | 04:38 PM
gmane's Avatar
Went to honda today and confirmed the CV and Axel are fine.. gonna try getting some wheel centric hub rings to see if that aleveates the problem.. if not then i'll switch wheels around and finally if that doesn't work i'll balance the wheels..
Old Apr 23, 2008 | 09:40 PM
your wheels are lugcentric by design. most wheels are these days.
those centering rings are there more for alignment and ease of installation
when you mount your wheels back on the car.
try the rotation trick first... you might not have to get those rings.
there are times those rings do help, coincidentally.
im not running centering rings on my current wheelset. no vibrations,
no issues.
Old Apr 23, 2008 | 10:37 PM
gmane's Avatar
no issues.
Hmm.. well i ordered them from a local shop, they are gonna cost me $20 and i'd hate to not pick them up after ordering them and getting a bad rep with the local guys so i'll take the hit for $20.. still gonna try the rotating trick too thou..
Old Apr 24, 2008 | 11:19 AM
oh.. yah, if you already ordered it definitely go pick them up from the store.
Old Apr 24, 2008 | 11:48 AM
Kuturagi's Avatar
well u might want those centering rings anyways... they take stress off of the wheel bolts... my mechanic had a civic with some enkei rims on it and after driving about 30k the bolts finally snapped and there went his rim under his car, being dragged to a stop... eeek!! It all depends on what wheels you have I suppose. I would just put the stock wheels on and see what you can tell from that.
Old Apr 24, 2008 | 12:06 PM
gmane's Avatar
Yeah i'm gonna put the rings on it only cost me $20.00 so no biggie..
TaubBaer
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Jan 23, 2015 10:34 PM
xonexlifex
13
Mar 6, 2011 04:16 PM
NBPturtle
Mar 24, 2010 10:25 PM
Callista
Jan 2, 2009 11:01 AM
4dr4life!
23
Jul 17, 2008 11:43 AM
