New megan downpipe... ( help)
Old Apr 24, 2008 | 08:58 AM
Zangoose GD3 Blue's Avatar
Im thinking of getting the New megan downpipe, and im afraid i might leaning the sh!t out of my car... to stop the leanness i just need to get new injectors or something else
Old Apr 24, 2008 | 09:34 AM
SickFit's Avatar
Naw, your good to go. Just install and drive.
Old Apr 26, 2008 | 07:41 PM
tonyd3773's Avatar
I have the downpipe from Megan w/ a Header...Axle Back & CAI my A/F ratio was 10.2...which is pretty rich. If that helps any.
tonyd
Old Apr 26, 2008 | 09:15 PM
kirko's Avatar
You people are crazy on this forum about mods and leaning out the car. Its fuel injected, not carbeurated, there is wayyy less of a chance of anything going wrong with a fuel injected car, fuel wise. The injectors im certain about are not anywhere close to 100 percent duty cycle, so the ecu has plenty of room to make adjustments if need be. It would be pointless to put larger injectors, because then you would be spending thousands on a standalone and a tune on something you dont need. Even worst case scenario, your car goes lean as crap, it will start to sputter, and you will need new spark plugs. its not turbo, its hard to melt a piston on a stock n/a car.
/end rant
Old Apr 27, 2008 | 01:47 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
/end rant
Lurk around the forum first before posting about this. Certain headers and a cat-deletes bring AFR's close to 14.0 in WOT. While people are saying thats safe, the Fit stops making power if AFR's pass 13.5.
Zangoose, you wont run lean with the Megan. Remember its a header AND a cat-delete. And if youre still afraid of it, dont put bigger injectors in. Your car will be slower than ever.
Get an SAFC and have it tuned by a reputable Honda tuner.
Not only will you be more comfortable, youll make more power.
What tonyd mentioned should help you. 10.2 is beyond rich, even for a turbo car.
Old Apr 27, 2008 | 07:46 PM
Awesome thanx for the help...
Old Apr 27, 2008 | 08:57 PM
QuickGD3's Avatar
tonyd
But you are a proud owner of a FIT that put down 139whp and 131tq!!
Ciggy
May 24, 2010 08:23 PM
sevenaprils
31
Nov 16, 2008 12:48 PM
moondog
Jul 16, 2008 10:27 AM
SickFit
Mar 16, 2008 04:06 PM
pastadog
Feb 3, 2008 10:41 AM
