Sponsored by:
Sponsored by: CARiD
oil filter relcator..
Old Apr 25, 2008 | 03:23 PM
randomracer's Avatar
went to Cerritos Honda for and oil change and saw the fit in the show room... with a turbo setup ..anyways it had a oil relocator ... any one know where i can get a reliable one(don't trust ebay)
Old Apr 25, 2008 | 03:48 PM
s0x's Avatar
s0x
i talked to the guys there an he said that most of the parts were crap like the turbo set up was just a top fuel one so probably it was from ebay or the same quality lol
Old Apr 25, 2008 | 05:01 PM
manxman's Avatar
Auto Parts, Motorcycle Parts, Car Parts, Truck Accessories & Parts, Auto Accessories - JC Whitney, and Amsoil also makes several models.
Old Apr 25, 2008 | 05:23 PM
Tofuman's Avatar
The oil filter is in such a good location already, why would you want to move it? You probably never have tried to chance the filter on an EP3 or DC5... those cars need a relocator!
Old Apr 25, 2008 | 05:41 PM
TurboManGT's Avatar
Hahaha hell yeah they do
Old Apr 25, 2008 | 09:07 PM
manxman's Avatar
Originally Posted by manxman
randomracer-
In addition to the previous two comments, I can understand that the hardware for a turbo setup could interfere with the normal oil filter placement. A relocator is just an adapter plate that screws onto the threaded pipe that receives the normal filter, and seals with an o-ring to the stock filter plate on the block. The new adapter comes with a hose and threaded fitting that screws into the adapter plate. There is another filter mount plate with hardware to attach the new plate somewhere else in the engine bay, where you screw on your oil filter.
Where the heck will you put that? You will probably need to throw away your windshield washer tank, because that's how much space you will need. If you use super short Short Ram Intake, with the filter very close to the throttle body, you will have enough room near the fender to place the new remote oil filter mounting plate.
Good luck!
Old Apr 28, 2008 | 01:39 AM
after reviewing what you guys posted and thinking... i don't think i am going to go with it... i just wanted it to make oil changes easy and to look cool
Old Apr 28, 2008 | 02:10 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
it really cant get any easier than it already is
freakin k20, reach halfway up the block, untwist filter out, and have nice warm/hot oil drip down your arm and all over the LCA, Axle, etc.
Old Apr 28, 2008 | 03:16 AM
QuickGD3's Avatar
Same thing with the B-Series motors
Old Apr 28, 2008 | 04:07 AM
Spreee's Avatar
i hear ya on that. old civic si
Old May 12, 2008 | 11:54 AM
itsmeb*tches's Avatar
You think the B-series is bad try changing the oil on the H22 SH block. That is the worse design off an oil filter location I every saw.
Old May 12, 2008 | 04:04 PM
doctordoom's Avatar
Supervillain
i didn't specifically look in their fit's engine bay, but isn't their filter relocated because they most likely installed an oil catch can because of the addition of a turbo?
Also, i was just their today getting some engine coolant and i took a look at their fit's brake kit. aren't their rotors on backwards? and if you look at the rotors you can see that the brake pads only contact about half of the rotor. i wonder if they ever tracked that car or if they just threw on a buncha parts for show.
Old May 13, 2008 | 12:22 AM
dont know ill ask next time... but it looks real good...
JDMxGE8
124
Feb 15, 2015 10:14 AM
lcq4blackstar
Sep 3, 2011 06:25 PM
Lek
Jul 4, 2009 03:34 AM
azncarbos
Feb 5, 2008 01:45 AM
coldstorage5
May 4, 2006 07:21 AM
