Radiator fan is always 'ON'
Old Jul 28, 2005 | 07:40 AM
gansen
Guest
Posts: n/a
Hi, my wife own a Honda Civic 1990.
The problem is that the fan is always on when she starts the engine even
during the winter season.
Any solution to this.
thanks
Old Jul 28, 2005 | 09:30 AM
Remco
Guest
Posts: n/a
Re: Radiator fan is always 'ON'
> thanks
Not sure where the thermoswitch is on a 90, but my bet is that this
switch is shorted (constantly on) or the wire from it has shorted to
ground.
tegger.com has a cooling section that may help you.
Remco
Old Jul 28, 2005 | 10:30 AM
Bruce
Guest
Posts: n/a
If it's a 90, I just went through finding that thermo switch myself...
It's under the intake manifold, next to the oil filter.
My various manitenance manuals either say it's located at the bottom of
the radiator or on the thermostat housing. On a 90 Civic EX, (pretty
sure CRX is different) it's at neither place, but under the intake
manifold next to the oil filter... the only way to access it as far as
I know is from beneath. Need to wrap new switch threads with teflon
tape per the Helm manual. I got mine at Napa and it came with new
o-ring.
Good luck.
Old Jul 28, 2005 | 12:30 PM
r2000swler@hotmail.com
Guest
Posts: n/a
A friends 1990 4S manual has teh radiator thermo switch on the lower
left, standing in front. It controls a relay that supplies power to the
fan motor. The thermo switch closes to ground when hot.
So either the switch is failed shorted or a wire is pinched to ground.
The relay could have failed closed but that is a long shot.
Terry
LastDance
May 30, 2007 11:21 PM
Gary
Oct 13, 2005 11:31 PM
Al Davis
May 15, 2005 07:30 PM
TeGGeR®
DesignGuy
May 4, 2005 11:16 AM
