is there a difference between...
Old May 1, 2008 | 12:05 PM
los_creeper's Avatar
Question is there a difference between...
jdm and usdm, as far as suspension goes? i found a "sports" set up from honda made by showal on japanparts.com : PARTS DATABASE with a 25mm drop which is about an inch, which would be fine with me since it's all honda official parts, ya know, just for warranty purposes and such.
will it fit our... fits?
Old May 1, 2008 | 12:08 PM
JDMchris.com's Avatar
I run THIS
you have to slightly modify them.
Old May 1, 2008 | 12:29 PM
can you please quantify what is 'slightly', thansk.
Old May 1, 2008 | 12:31 PM
I run THIS
You have to make the bolt holes a little bigger.
Old May 1, 2008 | 02:57 PM
Tofuman's Avatar
i believe the spring rates will not be perfect for USDM fits. being that the JDM fit is lighter weight. not sure it is a big deal or not.
Old May 2, 2008 | 01:20 AM
claymore's Avatar
Not a big deal as it's only a 100 lbs or so.
Old May 2, 2008 | 07:57 AM
that 100lbs might slightly even compensate for the bad roads out here....
which is a good thing.
onetwothree
Mar 14, 2015 11:53 AM
bana1988
Aug 12, 2011 10:12 PM
J-Hov
Oct 22, 2010 01:02 PM
hondafitgow
Hawaii Community
May 18, 2009 04:52 AM
fitinfit
Sep 13, 2007 11:52 PM
