sidemarker wiring
Old May 8, 2008 | 11:14 AM
mikow's Avatar
sidemarker wiring
hey guys,
when you guys did your sidemarker wiring..
did you guys take off your front bumper to give you more access to work on the wiring?
need to know.. doing this on saturday...
also any tips on cutting into the car and wiring,
basically any tips on installing sidemarkers?
i have a template already and the right tools
-mike
Old May 8, 2008 | 03:41 PM
mikow's Avatar
anybodies?
Old May 8, 2008 | 05:37 PM
yeamans17's Avatar
As with anytime you cut into a body panel always make sure the hole is where you want it to be (obviously). Then make sure its lined up where you want it, and always make the hole smaller than you intend it to be in the end, its easier to cut away the extra than it is to replace and paint a fender (not to mention a hell of a lot cheaper). I haven't installed a set on my Fit yet, but I know when wiring my accord sidemarkers it was helpful to have the bumper off for the purpose of running the wiring through the fender.
Old May 8, 2008 | 06:16 PM
SD_MR_FIT's Avatar
cut a tiny hole. then use the filing tool on the dremel to file how big you want the hole to be. keep test fitting, you want that sidemarker to be tight!
and i wired it through the fender. it is easier to take the bumper off so you can get to the headlights easier.
Old May 9, 2008 | 01:09 PM
mikow's Avatar
ok guys, i'm cutting into my car tomorrow! haha.
i'm also gonna do the DIY painted black housing for fogs.
any tips on what paint to use or any tips on for tomorrows installation and DIY???
Old May 9, 2008 | 09:53 PM
Spooling's Avatar
I used duplicolor's high-gloss black for the foglights.
Hey could you tell me how to wire up the sidemarker? like which wire do I tap power from?
ajynks@gmail.com
Aug 14, 2016 09:03 PM
sloganmartin
Sep 20, 2012 01:23 PM
Sahilchaddha
Oct 5, 2011 04:57 PM
davmbar
Sep 4, 2010 01:50 PM
rlewis123
Dec 27, 2007 12:28 AM
