So which tail you think will look better
Old May 12, 2008 | 10:59 AM
Rod2Rice's Avatar
Debating between these 2. Which do you think will look better with the BOM? With gunmetal colored wheels coming this week, and the tinted windows, I am almost thinking the first one may look better. My only concern with the first ones is if the LEDs will be bright enough. the 2nd set is also cheaper by 100 bux so in that respect its appealing. But the first set I have not seen as often on a lot of the cars you guys have on here. Any input on if either needs the wiring extended also, from experience?
Old May 12, 2008 | 01:31 PM
azncarbos's Avatar
the first I would be care for w/ the fitting and also the seal around the trail light.....and if go with the second I would recommend going w/ N1 or Depot or the Real One....also no matter which one you pick, you will still need to extended the wire. But it up to you.
Old May 12, 2008 | 03:56 PM
doctordoom's Avatar
Supervillain
i like the second set of lights better. too much clear-ness for me in that first set of lights but that's just my opinion. i don't think you should have any problems with visibility using LEDs though.
Old May 12, 2008 | 08:23 PM
jezzy's jazz's Avatar
that first set looks like lexus lites, its so played out...
marmaladedad
21
Aug 7, 2019 03:03 PM
niko3257
16
Mar 24, 2017 06:45 PM
TKE
Apr 27, 2014 06:22 AM
77vetter
Aug 4, 2011 02:48 PM
MarkyMark
Atlanta Community
Dec 28, 2009 03:04 PM
