WTF??? Has anyone ever seen this?
Old May 12, 2008 | 07:23 PM
ClaytonS15's Avatar
I've been experiencing vibration at highway speeds, so I took a look under the hood. Look what I found: Broken engine mount bolt on the passenger side.... I've never heard of this problem before. I'm taking it to the dealer tomorrow. I expect them to repair this under the powertrain warranty. Certainly explains vibration if the damn engine is moving!!!!
Old May 12, 2008 | 07:25 PM
ciburri's Avatar
It is not unusual for one bolt to go from the top and other from the bottom when it comes to motor mounts. "Feel" it from underneath.
Ivan
Old May 12, 2008 | 07:27 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Is there a bolt there? Or is there suppose to be a stud with a nut on it?
Old May 12, 2008 | 07:28 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
no, it's supposed to be broken.
you're all good.
you're probably just imagining the vibration.
haha jk.
that sucks though.
hope they fix it!
Old May 12, 2008 | 07:30 PM
Posts in the NUUDE
I just checked my car. Thats normal and it doesnt seem like youre missing the bolt as I can see the end of it.
Your vibrations may be the front transmission mount though.
Here you go
https://www.fitfreak.net/forums/fit-...7-writeup.html
Old May 12, 2008 | 07:31 PM
cavie187's Avatar
Ooooops!
have not seen it on a fit. Other cars: yes, but this is a first for me.
Old May 12, 2008 | 07:32 PM
cavie187's Avatar
Let me find the thread.
It's just studded in there? that's kind of odd.
Old May 12, 2008 | 07:34 PM
Posts in the NUUDE
Its a bolt from the bottom of the mount as Ivan mentioned. Notice the nut to the right? Thats studded, then a bolt from the bottom on the left.
Old May 12, 2008 | 07:36 PM
cavie187's Avatar
OK. Gotcha.
The mount is threaded so no need for a nut on the end? Is that correct? It's just a flush bolt from the factory?
Old May 12, 2008 | 07:39 PM
Posts in the NUUDE
EDIT.
Hold.... Let me correct myself. Theres 1 threaded stud pressed into the mount.
2 nuts are used on either side of the mount. That stud and nut you see at the bottom of my pic looks the same on the other side of the mount. Except the stud closest to the bottom of the pic looks to be mounted to the engine.
Old May 12, 2008 | 07:54 PM
cavie187's Avatar
EDIT.
Perfect! explains it all. thank you.
Old May 12, 2008 | 09:03 PM
ClaytonS15's Avatar
Thank you very much for this information as I had just assumed that this bolt should have a head. Thanks for the info about the other mounts, I'll have them checked at the dealer.
Here you go
Old May 12, 2008 | 11:21 PM
Firebat666's Avatar
same thing happened on my parents CRV few years back... was told it was cuz the steering wheel had been jerked too hard too many times... wonder how that happened...
Old May 13, 2008 | 08:38 AM
i think you would see traces of where the bolt head was on the mount
if indeed that was a broken bolt.
Old May 13, 2008 | 10:59 AM
claymore's Avatar
Normal installation ..... the bolt head is not missing it's screwed in from the bottom.
Fitty McFit
Sep 18, 2018 09:25 PM
CJfit15
Dec 2, 2015 10:17 PM
koolkevin1107
Oct 8, 2012 07:33 PM
apexanimal
Jan 13, 2012 10:00 PM
Wave
24
Apr 28, 2008 01:05 PM
