A/C working improperly
Old Aug 11, 2005 | 09:30 PM
2ball
Guest
Posts: n/a
A/C condition is sometimes working and sometimes not working. This
happening is keep repeated back and forth everyday. Usually, When a
engine is cool,it does work great. But it is not working(blowing warm
air)as soon as engine is gets hot after about 20 to 30 min with driving.
I took my car to a mechenic checked A/C gas and performance. It's o.k.
everything is fine. working great. It's very cold. When I got it back
to my home, problem starts again. Is something a relay problem or
somthing else? What is going on?
Old Aug 12, 2005 | 10:30 AM
E Meyer
Guest
Posts: n/a
Re: A/C working improperly
On 8/11/05 7:52 PM, in article
b003443737723f1bb045302d3c04ea94@loc...o utautos.com, "2ball"
It sounds like it might be icing up. When it starts blowing warm, pull over
and open the hood look at the A/C lines. If you see ice building up on them
(usually at the point where they go into the firewall), that's your problem.
The system is not properly charged.
If not ice, then probably the sensors that cause the compressor to stop when
there is either too much or not enough pressure in the lines are engaging.
Same problem - system not properly charged.
There is a tendency to overcharge R-134 systems. Have you recently had it
serviced?
Old Aug 29, 2005 | 04:39 PM
'Curly Q. Links'
Guest
Posts: n/a
It sounds like he overfilled it. The system will stop the compressor for
too low pressure, and if it goes too high. Might be why it works OK
until it warms up.
'Curly'
jimmypackman
May 3, 2016 03:12 PM
hydrogennine
Sep 7, 2011 11:59 PM
Fit4Pits
Aug 3, 2009 12:35 AM
ernests131@charter.net
Jul 3, 2005 02:44 PM
punkyw
May 15, 2005 07:30 PM
