Hood Pins
Old Aug 12, 2005 | 01:32 AM
Elle
Guest
Posts: n/a
Hood Pins
Has anyone installed these on his/her Honda?
Any thing I should look out for while installing?
What manufacturer of hood pins do you like?
My 91 Civic's hood release lever and cable mechanism have been a pain for
many years. I am thinking of discarding the whole setup, sacrificing looks
for easier access to under-the-hood.
Old Aug 12, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
Re: Hood Pins
as a cyclist, i have a significant objection to hood pins. when i
bounce off the front of your car, now i will not only have the bruises
of impact, i will have gouges and tears of pin penetration. please just
fix the mechanism instead. there's quite a lot of adjustment in the
latch position and the pin height that should alow you to get it working
right. and replacing the cable is pretty easy once you have the bumper
& wheel well liner off.
Old Aug 12, 2005 | 11:30 AM
Elle
Guest
Posts: n/a
Re: Hood Pins
"jim beam" <nospam@example.net> wrote
snip
I have never heard of an accident such as you describe; there are few
cyclists in my area; your request is like me asking you not to drive above
the speed limit.
It's the hood release lever (in the passenger compartment) that has been the
problem.
Old Aug 12, 2005 | 10:34 PM
jim beam
Guest
Posts: n/a
Re: Hood Pins
> snip
> the speed limit.
> problem.
unfortunately, these accidents do occur, just like people with crash
damaged fenders that have sharp jagged edges... well, you get the picture.
the hood release lever is easy to fix elle. any junk yards near you?
Elle
Guest
Posts: n/a
Re: Hood Pins
> > snip
above
> > the speed limit.
the
> > problem.
picture.
No, I do not.
When you quit speeding with your car, then we can talk.
This malady is not easily repaired and is extremely common in Civics my
vintage. Go to any junkyard. The cable stretches, and a person is back to
square one.
Old Aug 12, 2005 | 11:34 PM
jim beam
Guest
Posts: n/a
Re: Hood Pins
>>>snip
> above
>>>the speed limit.
> the
>>>problem.
> picture.
> No, I do not.
dude, i'm the cyclist, not the idiot driving with metal shards hanging
off their crashed-but-never-repaired turnip truck.
> square one.
sorry, it /is/ easily repaired - i've done it. the handle is easily
replaced, the cable is easily replaced, and above all, the whole
shooting match is cheap.
fyi, the cables don't stretch, not at the tensions seen - the poly
outers wear, but that's it. don't confuse the fact that the catch is
designed to operate only at full lever extension with any malfunction.
benmaggoswd1
Mar 19, 2018 10:20 AM
mizike
Feb 14, 2018 05:51 AM
CrystalFiveMT
Dec 25, 2009 01:48 PM
FitnessJay
Dec 22, 2009 09:27 PM
Guinness
Dec 10, 2007 11:40 PM
