crankshaft bolt which way to loosen?
Old May 31, 2008 | 09:43 PM
xorbe's Avatar
All of my directions/manuals simply say, "Now loosen the bolt" ...
Old May 31, 2008 | 09:44 PM
kelsodeez's Avatar
UNBANABLE
lefty loosey?
rightey tightey?
Old May 31, 2008 | 09:45 PM
xorbe's Avatar
Translate that into clockwise or counter-clockwise facing the bolt, and do you know for sure.
Old May 31, 2008 | 09:53 PM
kelsodeez's Avatar
UNBANABLE
i dont know for sure. i havent loosened that bolt before. i looked through the service manual for you but i didnt find anything on it. maybe you can find something i couldnt
Engine Assembly and Mounts
Old May 31, 2008 | 11:19 PM
xorbe's Avatar
Well I found the special Honda/Acura 50mm crank pulley tool at Pep Boys for $40, so we'll give it another go next Saturday, out of time for today.
Honda and Acura Timing Belt Tips, Crank Pulley Tool
Old Jun 1, 2008 | 01:42 AM
claymore's Avatar
COUNTER clockwise looking at it like a regular bolt.
Old Jun 1, 2008 | 03:11 AM
xorbe's Avatar
Excellent, that's what we were trying (crank spins clockwise normally, looking at the bolt). Oh man, I got to wait another week...
Old Jun 8, 2008 | 01:42 AM
xorbe's Avatar
Check this, I bent the 50mm tool trying to loosen the crankshaft bolt the "proper" way:
Foiled again, the car was lifting up via the 50mm + breaker bar. Plus I bent the pin in the breaker bar. The 50mm tool is pretty damn thick. That's one mean bolt.
Old Jun 8, 2008 | 02:05 AM
Sugarphreak's Avatar
Push My Button
Holy crap!!
Are you are trying it with a warm/hot engine?
Old Jun 8, 2008 | 02:24 AM
xorbe's Avatar
First I tried cold last weekend with impact and lousy breaker bar setup. This weekend I warmed up the engine to 202F and let it sit there for a while at 202F (fan kicks on at 204F), then hit the bolt with both impact gun and proper breaker bar + 50mm setup. The crank bolt was too hot to hold onto, so it was decently warm.
Next weekend I will try heating the bolt directly with a small propane torch or some such. After that, car shop!
Old Jun 8, 2008 | 02:39 AM
koolkevin1107's Avatar
DUDE i just hit mine with my craftsman 350lb torque impact wrench in my garage. Took 3 seconds 2 come loose. I didn't even use a tool to hold the crank, just hit the crank bolt with a stong impact gun.
Old Jun 14, 2008 | 02:36 PM
xorbe's Avatar
Central Pneumatic 1400 ft-lb FTW!
Old Jun 14, 2008 | 04:00 PM
Spooling's Avatar
^ good job! I know hwo fraustrating it is. A simple job turns to be disaster just of a stubborn bolt.
Kuturagi
Mar 29, 2012 04:25 AM
y950129
Mar 1, 2011 07:03 PM
F-IT!!!
Dec 23, 2007 02:25 AM
1coolride
Dec 8, 2007 04:20 PM
