stuck window
Old Aug 18, 2005 | 08:40 PM
hey_blue
Guest
Posts: n/a
stuck window
can anyone tell me how to get a power window up?...it's stuck down and I'd
like to get it up ...I need a window regulater and I want to buy some
time...any help is appreciated...thanks
Old Aug 18, 2005 | 10:38 PM
John
Guest
Posts: n/a
Re: stuck window
On a friend's lincoln you could pull the window up by hands. You just grab
it from both sides and pull up. I'm not sure if will work on a power civic.
ALl my civics have been manual windows so I'm not sure. You could try
openning your door, disconnect the motor assembly, pull the window up, and
put something underneath the window to hold it in place until you put the
regulator.
"hey_blue" <fpm911@aol.com> wrote in message
news:022d97009100b642e9d6b7c2ce158774@localhost.ta lkaboutautos.com...
Old Aug 19, 2005 | 09:51 AM
Dan Beaton
Guest
Posts: n/a
Re: stuck window
"hey_blue" (fpm911@aol.com) writes:
Are you sure the window is stuck? We had that happen recently and it turned
out that the window main switch had been turned off accidentally, disabling
the controls for all but the driver's window. The main switch is with the
other window swicthes on the driver's door.
Dan
(This account is not used for email.)
Old Aug 21, 2005 | 09:48 AM
B Squareman
Guest
Posts: n/a
Re: stuck window
On some Accords, use the battery to power the motor. If all else fails,
you might need to remove the motor to manually bring the window up
and shut.
Old Aug 31, 2005 | 11:30 PM
speedy
Guest
Posts: n/a
Re: stuck window
My daughters civic had the driver window pop out of its track. Bottom
line is you'll have to take the panel off and check all the components
to see whats really wrong.
-SP
patm95
Jun 22, 2016 11:36 AM
cKranez
Asia Fit Forums & Clubs
Nov 18, 2010 10:15 AM
BargainSeeker
St Louis Community
Aug 11, 2006 09:35 PM
Milleron
Aug 20, 2005 12:57 AM
Sam Nickaby
Jul 14, 2005 10:27 AM
