Wiper fluid problem
Old Aug 21, 2005 | 02:38 PM
Fijoy George
Guest
Posts: n/a
Wiper fluid problem
Hi all,
I have a 1991 Honda Accord which has this strange problem: the windshield
wiper fluid comes out of the nozzles only when I operate it with the hood
open. When the hood is closed, no fluid comes out. I can hear the motor
working and there is enough fluid in the tank. I also visually checked if
closing the hood somehow blocks the fluid flow by jamming the rubber tube,
but there is no sign of that either as far as I can see. Does anyone have an
idea what is going on?
Thanks
Fijoy
Old Aug 21, 2005 | 03:37 PM
'Curly Q. Links'
Guest
Posts: n/a
Re: Wiper fluid problem
Fijoy George wrote:
> Hi all,
> Thanks
> Fijoy
The tube is getting folded over. If you can follow the tube you'll find
a spot where it gets crimped. Have a helper run the thing while lowering
the hood. You'll see / hear it happen.
'Curly'
Old Aug 22, 2005 | 09:30 AM
TeGGeR®
Guest
Posts: n/a
"'Curly Q. Links'" <motsco_@_interbaun.com> wrote in
news:4308D3ED.DE332FB6@_interbaun.com:
> Fijoy George wrote:
>> Hi all,
>> windshield wiper fluid comes out of the nozzles only when I operate
>> it with the hood open. When the hood is closed, no fluid comes out. I
>> can hear the motor working and there is enough fluid in the tank. I
>> also visually checked if closing the hood somehow blocks the fluid
>> flow by jamming the rubber tube, but there is no sign of that either
>> as far as I can see. Does anyone have an idea what is going on?
>> Thanks
>> Fijoy
> find a spot where it gets crimped. Have a helper run the thing while
> lowering the hood. You'll see / hear it happen.
> 'Curly'
Replacement vinyl hose is very cheaply available at Home Depot, as well. It
has a bit thicker OD than OEM, but it still works.
TeGGeR®
www.tegger.com/hondafaq/
NooK
Jan 27, 2019 03:22 AM
adkfit
Dec 29, 2012 09:56 PM
kinosh
Dec 21, 2009 02:20 AM
xander
Feb 2, 2009 01:50 PM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
