90 Accord fan relay/motor
Old Aug 28, 2005 | 07:52 PM
Pete from Boston
Guest
Posts: n/a
I'm having what seems to be a not-so-uncommon problem in my 90 Accord,
where it overheats if not moving enough. After having cooling work
done, with the accompanying pressure test coming out ok (and most of
the system now replaced in the past year and a half), I checked the
cooling fan fuse. Blown. Replaced it, turned on the car, that fuse blew
immediately. What's the likely culprit? How much should the fix cost me?
'Curly Q. Links'
Guest
Posts: n/a
Re: 90 Accord fan relay/motor
The fan motor bushings are dry (worn out probably) Try spinning the fan
by hand. Brushes might be worn to nothing and shorting too.
'Curly'
Old Aug 29, 2005 | 05:33 AM
B Squareman
Guest
Posts: n/a
"Pete from Boston" <masspete@my-deja.com> wrote in message news:1125269602.312107.42410@g43g2000cwa.googlegro ups.com...
If you turn on the car and the fuse blows immediately, then this could
mean a bad switch and/or relay (which can wear out your motor's
slip ring prematurely and create a short, as Curley mentioned.)
You might want to unplug the relay. If the fuse still blows then the
short is before the relay.
Marrk
Sep 29, 2013 02:19 PM
xwikedonex
Aug 7, 2013 09:24 PM
Trogdor!
Sep 17, 2010 04:33 PM
willy2005
Jun 22, 2005 01:43 PM
dispman2000@yahoo.com
May 4, 2005 11:16 AM
