Replaced trans fluid and huge difference.
Old Jul 11, 2008 | 12:23 AM
underdog's Avatar
Hi I figured i'd let you guys in on a little trick that I just tried. I've been doing some reading on manual trans fluid and ran into a post where someone compared stock mft, redline shock proof, and gm syncromesh "friction modified" and they said overal the GM fluid was best. so I gave it a shot and it was a very noticable difference. the lovely 1-2 shift was a million times better, putting it into reverse is a breeze now and it also seems to drive a little smoother. it feels less notchy now. the fluid is semi-synthetic so we'll see if it helps with gas milage at all.
the fluid is a little pricey but I think it well worth the money. it only takes approx 2qts. you can buy it a any GM dealer, but make sure you get the "friction modified" version. it comes in a regular qt. bottle like oil. the standard syncromesh comes in a round bottle. part # 12377916
Old Jul 11, 2008 | 01:26 AM
SD_MR_FIT's Avatar
yes i voucher.
i use gm synchromesh in my car
ive used in in all my car actually.
sooo smooth. one day i will try redline...but im happy with my gm sychromesh
over here its 14 bucks a quart! eww.
well i think that how much i paid for it. all i know is its super expensive..but definitely worth the money.
Old Jul 11, 2008 | 01:55 AM
underdog's Avatar
yeah I paid $10.25 a qt. not cheap but still worth it.
Old Jul 11, 2008 | 02:19 AM
George02's Avatar
used this on my s2k, and it really does work
Old Jul 11, 2008 | 02:44 AM
fitinfit's Avatar
just bought them this past Tuesday, gonna put it in this weekend, can't wait!
Old Jul 11, 2008 | 09:36 AM
underdog's Avatar
word of advice. either hold the drain plug at a angle to control the angle of the fluid as it comes out, or pull the plastic panel foward otherwise when you drop the drain plug it will make a huge mess when it hits the frame rail and stays in the plastic panel underneeth. I also found it easiest to get a 3' piece of hose and a funnle then route the hose between the strut and body and fill it by the tire. its a little tight on space down there.
Old Jul 11, 2008 | 09:59 AM
GD3-Fit's Avatar
I <3 SPOON
i'm going to have to try this out
i used mobil 1 75-90W synthetic gear oil or something like that before in my s2k
never had any problems
but i've heard great things about gm syncromesh
-Ricky
Old Jul 23, 2008 | 02:42 AM
Masterdebater's Avatar
GM synchromesh? where do u get it at? when u say gm dealer u dont mean like chevy etc. do u? or can we just get it at autozone or kragen
Old Jul 23, 2008 | 08:25 AM
honda2112's Avatar
Is it temp sensitive if you live in cold areas?
Old Jul 23, 2008 | 09:02 PM
underdog's Avatar
i've read it actually helps in cold climates.
yeah any gm dealer should carry it. chevy, gmc, saturn, ect....
autozone, kragen, and other parts stores typically carry a comparable syncromesh fluid but it isn't the "friction modified" version typically. and there is a difference between the two.
Old Jul 23, 2008 | 09:29 PM
07fitsport's Avatar
guess this goes in MT and not AT right
Old Jul 23, 2008 | 09:44 PM
kancerr's Avatar
have my clutch changed and flywheel in 2 weeks. i will pick this up. thx.
Old Jul 24, 2008 | 02:16 PM
dewthedew's Avatar
Im going to pick this up when i get my short shifter/knob.
Old Jul 24, 2008 | 09:06 PM
Fit Love's Avatar
Fit Freak Member
I've tried the GM stuff and Redline, both are awesome.
Old Jul 25, 2008 | 06:46 AM
jchcmax's Avatar
The guys over at Acurazine go bonkers over GM synchromesh. I tried the GM stuff but found that Amsoil MTF works best for my TL.
Old Jul 25, 2008 | 07:00 AM
1500cc's Avatar
I've used redline for my past 4 cars and it's been great, but I'm always willing to try something new if it's that well talked about.
Old Jul 27, 2008 | 09:03 PM
wdb's Avatar
wdb
Any Motul users here? I have it in my STi and it is fabulous compared to the factory stuff.
Old Aug 9, 2008 | 07:21 PM
Hondady's Avatar
interesting. A good product with GM's name on it! Who would of ever thought! I just might have to try this stuff!!!
Old Aug 9, 2008 | 09:02 PM
spoonek4's Avatar
It's been a year that I haven't replace my MTF already. I'll definitely try that when I replace my clutch and put in my differential.
Old Aug 9, 2008 | 09:31 PM
da9rood's Avatar
Syncromesh is great.... but.... after time it softens the syncros and causes them to wear faster and normal, but it does make shifting better, Honda/Acura MTF is really the same as syncromesh but its a mix of a honda version of syncromesh and (10w30) motor oil. i would try redline or royal purple. if you really wanna spend some money look into Torco or Eneos. also i would get a megnetic drain plug for the engine and tranny, that helps alot on catching metal shavings from the oil
