15" questions
Old Jul 16, 2008 | 11:07 AM
roflmayorga's Avatar
15" questions
just bought a 08 base and im trying to find out what the widest 15 and the biggest widest tire that will fit stock suspension without rubbing and wich offset, looking to be flush with the fender
Old Jul 16, 2008 | 12:03 PM
Arisenfury's Avatar
I've got +38 and 205 and I rub in the back with stock suspension and in the front with a full wheel lock.
Old Jul 16, 2008 | 12:06 PM
FitSportGirl's Avatar
Good question roflmayorga. I've look for an to this question too. I'm guessing that wheels for either the Standard or the Sport will be the same. Correct? Also, maybe someone can explain to me understand wheel offset.
Old Jul 16, 2008 | 12:15 PM
trancedsailor's Avatar
The 15" wheels are the same for Base and Sport. Base comes with 14"s unless you check the option box for 15"s. Offset confuses me too, I think tirerack or discounttiredirect.com have explanations on all things tire. Camber, caster, toe, offset, etc.
Old Jul 16, 2008 | 12:52 PM
without lowering your car is going to look like a 4x4.
7" +40mm offset is the max you can go without rubbing given that you
run 195/50/15 all season tires.
KyleB2706
Dec 14, 2017 11:59 AM
kurisux92
Dec 15, 2011 10:08 PM
billyb
May 15, 2010 01:55 PM
inxsole
Nov 4, 2009 12:55 PM
