Different size tire question
Old Jul 19, 2008 | 07:44 AM
geepondy's Avatar
I see the stock base Fit tire size is 165/65/R14. My still good snow tires from previous vehicle is 185/65/R14 (wider). Will these fit on the stock base rim? Also if I just wanted to put the snows on a different rim rather then change over twice a year, where would I get and how much would the rims cost?
Old Jul 19, 2008 | 08:33 AM
kbh's Avatar
kbh
Since they are both 14 inch tires (rim diameter), the wider tire will fit on the rim. The problem is that the 185 tire has a larger outside diameter (22.5 vs 23.5) and will give you false odometer/speed info. Your acceleration performance may also suffer as you are essentially gearing the car taller with bigger tire. There may also be rubbing issues in the wheel wells if there is a lot of suspension travel. In addition, you generally want to run a narrower tire for snow driving. You can get cheap steel rims at many online tire dealers
Old Jul 19, 2008 | 09:54 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
As per tireracks database theyre 175/65/14's. Not many cars come with 165's now a days. Im actually surprised that theyre 175's. I thought most cars with 14's roll on 185's now.
185/60/14 or a 195/60/14. The 195 would be perfect. Might be hard to find.
Old Jul 19, 2008 | 10:20 AM
as mentioned above the profile is the same so your overall diameter is
also going to be a little taller.
should be ok as means of getting from a to b, probably...
Old Jul 19, 2008 | 03:44 PM
geepondy's Avatar
Yes, you're right, I read the tire size wrong. As stated per tire rack, they are 175/65/14's. Are the Dunlop stock tires really crappy? I was looking at the specs at tire rack and it doesn't even come with a tread warranty. I'm assuming you get at least 40k out of them?
utsug
Feb 17, 2017 09:44 PM
Thorzdad
Feb 2, 2014 08:56 AM
Splater
Mar 15, 2013 12:51 AM
d_2
Nov 19, 2011 06:51 PM
dcmcelreath
Jun 1, 2008 06:12 PM
