megan axleback problem
Old Jul 21, 2008 | 12:48 PM
ezduzit's Avatar
Love my Megan mid pipe and axleback, but the tips on the axleback are just a bit off.
The inside tip is a bit higher than the outside tip. The tips are square on the muffler itself, but when bolted up to the mid pipe, they are just enough off to bug me.
I loosened the spring bolts, pushed the tips in the direction they need to go to be square and retightened the bolts, but they're still off by the same amount.
I guess the next step would be to apply some violence to the hangers on the muffler, but I don't want to do that until I get some feedback here.
Old Jul 21, 2008 | 01:25 PM
dewthedew's Avatar
pics of the exhaust?
Old Jul 21, 2008 | 03:07 PM
ezduzit's Avatar
Will post a pic later today.
Old Jul 21, 2008 | 03:38 PM
Fitcapo's Avatar
Mine is just barley tipped to the outside of the car too. Not enough for me to do anything about it tho.
Old Jul 21, 2008 | 03:43 PM
manxman's Avatar
The offset has to be due to uneven height of the hangers on the body. With stock, 1-pipe exhaust, you can't see that it is lopsided, but the twin pipes make the offset of the hanger height obvious. I suggest using a length of 1/2" pipe, as an extension lever popped over the end of the hanger, to gently bend the higher side hanger down. It may take several small adjustments to get the twin pipes straight and level.
Old Jul 21, 2008 | 06:07 PM
ezduzit's Avatar
"Perfectionism is the enemy of good enough"
That bit of important wisdom has yet to sink into my brain.
Old Jul 21, 2008 | 06:13 PM
ezduzit's Avatar
Thanks!
Makes a lot more sense to adjust the hangers on the car than on the muffler.
I will post before and after pics after I get it done.
Old Jul 21, 2008 | 08:50 PM
manxman's Avatar
But why should anyone put up with "good enough"? If you have the ability, play God.
Old Jul 22, 2008 | 12:43 AM
ezduzit's Avatar
Things don't go well when I play God
Also, in the pursuit of perfection, it's easy to lose sight of the things in life that are really important.
Ok, that's enough armchair philosophizing for one day.
Prolly won't have a chance to get the Megan off and work on the hangers until Thursday afternoon. Will report back then and hopefully post some pics.
Old Jul 22, 2008 | 12:54 AM
saiko's Avatar
Avid FitFreak Poster
Have you tried cutting, shortening, and then, using a blow torch, reattaching?
jk
let us know your solution please!
Old Jul 22, 2008 | 01:46 AM
ezduzit's Avatar
jk
hehehe, I can see everyone with a Megan reading this thread going outside and eyeballing their exhaust, lol
Old Jul 22, 2008 | 03:02 PM
Arisenfury's Avatar
Mine sat square if I can't remember. I don't have it anymore though. Are you sure the curve in the bumper isn't just throwing you off?
Old Jul 22, 2008 | 03:14 PM
manxman's Avatar
In MY opinion, "good enough" isn't.
Old Jul 22, 2008 | 04:28 PM
ezduzit's Avatar
Yeah, I have a pretty good eye for symmetry.
Just to make sure the bumper wasn't throwing me off I just went out and measured the distance from each tip to the ground.
The outboard tip is at 10" exactly, the inboard tip is at 10 3/8". They're more than a 1/4" off.
Lots of people wouldn't notice or care, but I do.
Old Jul 22, 2008 | 04:30 PM
ezduzit's Avatar
Well, I guess in my opinion it isn't either cause I'm gonna do my damndest to fix it.
Old Jul 22, 2008 | 04:51 PM
manxman's Avatar
BTW, I'm not just offering idle advice. I have a Megan exhaust too, but mine hangs with the tips level. If they were uneven, I would just have bent the hangers and thought no more about it.
Old Jul 25, 2008 | 02:01 AM
ezduzit's Avatar
I never thought you were offering idle advice and I appreciate your help.
Old Jul 25, 2008 | 02:17 AM
ezduzit's Avatar
Ok, I worked on it this afternoon. I remembered that the tips weren't off as much before I installed my Megan b-pipe, so I took a look at all the flanges.
Sure enough, where the halves of the b-pipe connect in the middle, the flanges were a bit off and not lined up. I didn't have any leaks because I checked for that after the b-pipe install, but I didn't line up those flanges as well as I could have when I torqued the bolts down.
I loosened the bolts, rotated the pipe until it lined up and retorqued the bolts back down.
This gained me some ground but the tips were still not as square as I want them.
I took the axleback off and bent one hanger up a bit and the other down a bit. Reinstalled the axleback and there was much dancing and rejoicing.
BEFORE:
AFTER:
Old Jul 25, 2008 | 10:10 AM
Arisenfury's Avatar
Wow you got a horrible batch or something. Mine has never been that off and pictures of other's have never looked that off either. Not sure how long you've had it but you may want to try and contact your vendor and try and get it replaced.
Here's a shot of mine for comparison:
Old Jul 25, 2008 | 12:43 PM
saiko's Avatar
Haha you use a blanket to lie on while you get under the car?
(I use old towels. More comfy. HAHAHHA)
