orange fluid under car
Old Sep 16, 2005 | 12:30 PM
rynniki
Guest
Posts: n/a
Hey guys guess what I found orange fluid under the car again... taking it
to the mechanic today. what should i tell him to look for.. what do you
think it could b. the fluid was near the front of the car possibly right
under the thermostat sensor....also what color is manual tranny fluid i am
trying to narrow possible problems down it has a new clutch only 3 years
old and i ahvent noticed any tranny problems. what are symptoms of manual
trannies going bad ?
Abeness
Guest
Posts: n/a
Re: orange fluid under car
Orange fluid is coolant. Manual tranny fluid is the color of motor
oil--it's the same stuff.
High Tech Misfit
Guest
Posts: n/a
If it's orange, it's probably coolant. Perhaps your radiator is leaking.
Old Sep 16, 2005 | 01:31 PM
rynniki
Guest
Posts: n/a
even though the coolant in the radiator is green how does it turn orange
rynniki
Guest
Posts: n/a
whats funny is the coolant level in the radiator is fine but the reserve
tank is always at mininum unless the car was running and the car doesnt
overheat and i just squirted down where the fluid was and the asphalt got
eaten away and it was only from overnight.
Old Sep 16, 2005 | 03:38 PM
butch burton
Guest
Posts: n/a
The ATF -automatic transmission fluid - in my honda is red to a bit
orange - maybe this stuff is atf. However you describe your reserve
tank being at the bottom - fill it to the proper height - you can
remove the tank to make this task easier. Keep track of the level - if
it keeps falling - you have a coolant leak.
Check your atf level - the owners manual will tell you how. Oh - smell
of the atf dipstick - if it smells burnt - time to replace it - IMHO
honda atf should be replaced every 35K miles - not the 70K listed in
the manual. USE ONLY HONDA ATF - some brands say they are compatible -
could be a pricey mistake not to use honda atf.
Old Sep 20, 2005 | 09:30 PM
KWW
Guest
Posts: n/a
Ever thought that the overflow tank might be cracked?
KWW
'65 Beetle (Jenny the IOC)
'64 Beetle (TBD the Blue Wave)
"rynniki" <rynniki@wmconnect.com> wrote in message
news:c205c71879161078356e2a883a200653@localhost.ta lkaboutautos.com...
666fit666
Dec 14, 2023 11:24 AM
cakacon
Jul 26, 2023 05:30 PM
benareeno
Oct 25, 2022 01:39 PM
JerryHughes
Jul 13, 2019 11:09 AM
Kofi Anim-Appiah
Aug 6, 2005 04:43 PM
