with header no heat shield
Old Jul 30, 2008 | 06:51 PM
Spooling's Avatar
the oem heat shield doesnt bolt up to the new header. I noticed the temperature inside the engine compartment has risen a lot without the heat shield. is it ok to leave it like this or should i do something about it?
Old Jul 30, 2008 | 08:07 PM
Sugarphreak's Avatar
Push My Button
Should be fine, most after market headers do not allow the heat shield to be re-installed. If you have concerns there is a thread titled "How to get more air circulation under the hood" which has several good ideas and solutions to lower under hood temps.
Old Jul 31, 2008 | 12:35 AM
alexfree05's Avatar
what header is it?
Old Jul 31, 2008 | 12:53 AM
Push My Button
A fit from Richmond... I put money on it being a T1R or J's
Old Jul 31, 2008 | 03:15 AM
08FitSport's Avatar
Insulate that A/C line going into the fire wall with insulation foam from the hardware store. It will keep the air ice cold.
Old Jul 31, 2008 | 03:42 AM
ezduzit's Avatar
You can put the OEM heat shield back on with stainless zip ties.
Old Jul 31, 2008 | 01:03 PM
Evotech8's Avatar
Or you can reuse the oem heat shield by welding threaded studs/tabs on the new header. Thats what I did.
Old Aug 5, 2008 | 03:36 PM
Arisenfury's Avatar
I never noticed mine getting much hotter, are you sure it's not just the summer heat?
kodo
Jul 14, 2009 05:26 PM
im the fit
May 30, 2009 01:28 PM
im the fit
13
May 22, 2009 02:17 PM
jaebee
Aug 9, 2008 05:30 PM
ezduzit
Apr 22, 2008 02:54 AM
