The 500-mile club
Old Aug 9, 2008 | 02:16 PM
Burbio's Avatar
The 500-mile club
This thread is for anyone that has gone over 500 miles on a tank of gas.
Use this format:
Total distance on tank:
MPG:
Any practical modifications?:
Technique:
AT or MT?:
Old Aug 9, 2008 | 02:17 PM
Burbio's Avatar
Total distance on tank: 519.9 miles
MPG: 53.28
Any practical modifications?: SRI, CatBack, 2-inch drop
Technique: Removed the rear seats, cruise controlled at 55.
AT or MT?: AT
Old Aug 9, 2008 | 04:30 PM
Rockrover's Avatar
Distance: 502.5
MPG: 46.3
Mods: None
Technique: P&G ICE-off and on, N-ICE-glide. 5mph below posted 55 and 65 typically cruse on
AT
Still have some work to do, but getting better!
Old Aug 9, 2008 | 08:18 PM
pcs0snq's Avatar
I made 600 but with the FAsing shorted my odometer 10 miles or so...
12.4 gal tank was totaly empty
597 miles Odometer
Old Aug 10, 2008 | 02:02 PM
Burbio's Avatar
Originally Posted by pcs0snq
BTW Based on testing you will have to deliver 41mpg FE if your willing to almost drain the tank and 47mpg if you fill up when the E light comes on. ...to get that 500 mile tank in your Fit
I ran mine dry on purpose last week to see what a Fit gas tank really holds on my quest for a 600 mile tank. I had a measured 1 gal gas can in the back and when she started to sputter, simpley pulled over and added the gal. It was no big deal. Not surprised nobody had the nads to find that key data point out.
12.4 to 12.5 is all she holds
The neck may hold 1/3 gal tops
Tons of misinformation on that in here
i'm not sure i understand what you're saying, but when i did it, i went 520 miles and when i filled up it only took 9.757 gallons, so it worked out to 53.XX mpg.
Old Aug 11, 2008 | 12:36 PM
AppleMac*Fit's Avatar
Total distance on tank: 504.4 miles
Fuel Used: 9.708
MPG: 52
Any practical modifications?: lightened gas foot, changed philosophy of driving
Technique: P&G, DWL, keeping at 50 MPH on highway
AT or MT?: MT
Old Aug 19, 2008 | 08:43 PM
constar's Avatar
Finally got a 500 miler!
total distance: 502.5
10.53 gallons
47.7 MPG
Slow accel and driving 52-55 hwy.
AT
Old Aug 23, 2008 | 12:25 PM
Mattocaster71's Avatar
I thought the Fit only had a 10 gallon tank.
Wow...over 500 miles per tank. I guess I need to keep practicing.
Old Aug 23, 2008 | 12:35 PM
pb and h's Avatar
How is this:
Old Aug 23, 2008 | 04:28 PM
Rockrover's Avatar
Now I gotta' chime in and call "rubbish"!
Care to explain this young man?
--D
Old Aug 23, 2008 | 04:59 PM
pb and h's Avatar
LOL!
I wouldn't believe a word of it either if I haven't seen it and done it myself. So, I topped off the tank literally:
That added an additional 3 gallons after the first click(auto shut off of the gas pump).........I know it is suppose to be a 10.8gallon tank but it can hold more........I was a nonbeliever too. Like I said, I never believed it until I did it. So, if I have about 13-14gallons of gas and I achieve 60-65mpg for the whole tank then I should achieve 780miles-910miles for the tank.
Hell, I just topped my wifes 2008 CRV and it took an additional 4 gallons after the first shut off.
Old Aug 23, 2008 | 05:50 PM
pcs0snq's Avatar
Ohh man I knew it would show up in time.
Now watch the fur FLY
The fact is I was biotchen about my poor repeatability on my Fill and Wayne suggested I do this so I did as well as Shawn.
Now Shawn being the blabbermouth has infected you Freaks as well
We do this as a test and we are skilled Hypermillers. This is not recommended so kids do not try this.
Old Aug 23, 2008 | 08:10 PM
madhatch's Avatar
got 403 miles off 9.7 gallons.. no hyper miling. just normal driving.. @ speedlimit.
Old Aug 25, 2008 | 03:22 PM
Rockrover's Avatar
Awwww, I knew it!
That's it...I'm gonna' try it too.
BTW, my current tank is in the 'tank'. Way too much stress at work has caused much A/C use (everywhere), 4.5k rpm merging, and a bad case of the **ckit's when it comes to N-coast/FAS, etc.
Probably looking at 38mpg this tank. However I'm gonna' try hard to keep my over 40 for EVERY tank whole. Avg. will still be over 40 though.
--D
Old Aug 27, 2008 | 10:00 AM
pb and h's Avatar
Results:
Topped off tank before and after fill to get the max distance. P&G from 45-35 on local hwy and P&G from 52-45 on interstate. Shifted at 2K.
Used 13.2 gallons = 65.4mpg
I guess I could of safely driven another 52 miles if it holds 14gallons. I just wasn't sure how much it holds and how accurate the fuel gauge was reading. I wasn't willing to run out of gas...... (I chickened out!)
Old Aug 27, 2008 | 03:33 PM
Fit4Trav's Avatar
You guys are nuts
I dont think I'll ever get over 40MPG, and I think I drive conservatively with a little bit of spirited driving ever so often to pass others.
Now for filling up the tank/fuel line that much isn't there any cons that could occur?? I would think this would be dangerous/bad for the car.
Old Aug 27, 2008 | 09:22 PM
Scratch&Dent's Avatar
Man, it's hardly worth posting after that
Well, I got 47 MPG on 11.1 gallons, 518.1 miles for the tank. Personal best.
AT (with paddles)
P&G whenever possible, 62-50 on the freeway most of the time (lousy AT gearing). Personal best commute was on this tank: 50.3 in, 45 out.
Mods (also in my sig): T1R carbon fiber intake, T1R Response header, Skunk2 50mm catback.
It would be better, but it's just too tempting to get on it juuust once in a while...
Old Aug 27, 2008 | 09:28 PM
Burbio's Avatar
that's not bad at all. in fact, filling the tank until it's ready to overflow is cheating, at least in my book.
you say you used P&G... did you shift into neutral to do that? because that gives worse mileage than just taking your foot off the gas.
Old Aug 27, 2008 | 09:46 PM
Black01's Avatar
I'm beginning to see my Fit shine, at first I was doubting when a member post a 400+ miles a tank and calling it BS . Now I'm almost there and probably will go over 400, the thing is on the first quarter tank I was driving the card hard because I was late going to work. On my next tank of gas I will aim to get 500+ miles.
Old Aug 28, 2008 | 11:50 AM
pb and h's Avatar
AT (with paddles)
Man that is excellent for an AT!
You obviously know what you are doing so don't listen to the others on here that don't know what they are doing. Keep up the good work!
Getting on it is sooooooooooo hard to resist. It took me 1.5 weeks of not driving over 45mph(for most of my trip) in a 60mph zone!!!
You obviously know that the slower you go the better mpg you will get but is it worth it??? It isn't worth it for me to keep driving how I did on that record tank(for me). I am going to leave it up to someone else to exceed that mpg and mileage. I am captain impatient!
