Is modified Honda saved gas?
Old Sep 23, 2005 | 04:44 AM
mmdir2005@yahoo.com
Guest
Posts: n/a
Could any owner of modified Honda honestly answer that question?
Old Sep 23, 2005 | 07:07 AM
TeGGeR®
Guest
Posts: n/a
Re: Is modified Honda saved gas?
mmdir2005@yahoo.com wrote in
news:1127462066.153189.245290@g43g2000cwa.googlegr oups.com:
If "modified Honda saved gas", don't you think Honda would be modifying
them that way themselves already?
TeGGeR®
www.tegger.com/hondafaq/
Old Sep 23, 2005 | 09:30 AM
'Curly Q. Links'
Guest
Posts: n/a
How 'modified' do you mean? A lot of POWER modifications will actually
improve fuel mileage (a few go the opposite direction).
Anything to improve the aerodynamics, or lighten the vehicle will
improve mileage. I hand wax mine and the fuel mileage goes up. So does
my self esteem. Alloy wheels save on weight. 32+ PSI in all four tires.
Removing the back seats and throwing the spare tire away will help too.
Radio and speakers are heavy, and a full tank of gas is almost like
carrying a passenger.
Improving the airflow into the engine, as well as reducing back pressure
of the exhaust (within limits) will also increase the volumetric
efficiency.
Proper underdrive pulleys are impossible to find, but they can help too,
again, within limits. Most of the time you don't need you power steering
and alternator spinning that fast, and less drag from the AC wouldn't
hurt either.
'Curly'
Old Sep 24, 2005 | 01:31 AM
zonie
Guest
Posts: n/a
Well said Tegger. Scott
Old Sep 24, 2005 | 03:30 AM
mmdir2005@yahoo.com
Guest
Posts: n/a
A modified one working harder for engine? If so, does it require more
gas to
push piston faster? Is not more pump of air into does not saved gas?
Old Sep 24, 2005 | 07:30 AM
TE Cheah
Guest
Posts: n/a
mysterious posters get no info fr me
Honda fits cheaper parts on its cheaper models ; users' petrol bills are not
borne by honda. Result is e.g. lower though adequate torque @ low rpm (
as during buyers' test drives ), but very low ( <˝ as much ) torque & mpg
@ high ( >3000 ) rpm.
Every low end model's manufacturer strikes a balance between cost &
efficiency, e.g. F1 race cars use *carbon fibre ( has just 44% the weight of
steel ) in front wing, but a civic / city cannot have * ( too expensive ).
Old Sep 25, 2005 | 09:30 PM
Gordon McGrew
Guest
Posts: n/a
Before you even try to figure out what this guy is talking about, be
advised that he is a whacko who thinks putting electric clocks in cars
is a defect because they can prevent the car from starting.
pcs0snq
May 21, 2008 10:48 PM
TeGGeR®
Oct 12, 2005 02:30 PM
k r u d l e r
May 4, 2005 04:44 PM
TeGGer®
Debasis Goswami
