HKS kit with more boost? MBC?
Old Aug 12, 2008 | 11:39 PM
1990hondahf's Avatar
Question HKS kit with more boost? MBC?
How many PSI is the F-CON tuned for MAX? I know the kit, and therefore, the wastegate, is set for 5.7ish....but what if you up'ed it with a MBC....how high can you go?
Old Aug 12, 2008 | 11:44 PM
Fa1's Avatar
Fa1
There probably isn't a max psi at all. If you up the psi you'll need to get it re-tuned anyways. Then your limits are what the turbo can handle and the stock map sensor which probably can't read much over 10~15 psi (over atmospheric pressure).
Old Aug 15, 2008 | 11:51 PM
artieman's Avatar
Stock map sensor is .7 bar....good for 10.29psi at sea level....after that you will throw cel.
Old Aug 19, 2008 | 12:52 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
i heard it's actually not good to do.
Old Aug 19, 2008 | 01:30 AM
kelsodeez's Avatar
UNBANABLE
stock map sensor is 1bar. which is 14.5psi the values of air to fuel are set in the ecu to not exceed a certain parameter. so you will throw a cel with a spike in your map voltage or just too much air. a piggyback to the ecu tricks it into adding more fuel than it physically can. this confuses the ecu.
Old Aug 19, 2008 | 01:33 AM
kelsodeez's Avatar
UNBANABLE
i have talked to many people about MBC vs. replacing the wastegate spring. everyone of them say that using a MBC isnt a good choice on a mechanical type external wastegate. a MBC will work to add psi but i am going to take the advice i was given.
Old Aug 19, 2008 | 01:37 AM
yes, kelsey was the one who actually told me about this whole thing
Old Aug 21, 2008 | 11:29 PM
artieman's Avatar
Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
What is a 3 bar or 2.5 bar map sensor or an aftermarket map sensor used for?:
An aftermarket map sensor is used for forced induction vehicles which are to be tuned over 11 psi of manifold pressure. The factory Honda map sensor only supports up to 11 psi of map pressure.
pgmfi.org • View topic - Stock MAP + Boost
its actually 1.7bar absolute.
lookup the specs on the denso map....ive tuned 100's of honda's and have yet to see a map sensor even do the full .7bar over absolute since the ecu clamps at 4.5volts and wont allow the full 5
this is why the "high boost" kits for the fit only do 10psi...
part#37830-PNC-003 same map used in the tsx rsx and 03 up accord.
1990hondahf
28
Aug 6, 2011 10:13 PM
explosivpotato
35
Aug 15, 2009 02:57 AM
Spooling
May 29, 2009 02:20 PM
xtreme
Apr 1, 2009 06:59 AM
gthumb23
Oct 18, 2006 01:05 AM
