honda accord abs problem// curly q!
Old Oct 4, 2005 | 03:30 PM
jazzy29
Guest
Posts: n/a
Thanks very much, got code just as you said. 10 out of 10. was tucked under
passenger dash on dead plug. there was 2 multi plugs, 1 split into 2
smaller plugs (blue and red wire) these were wires to jump. only prob is
said left rear wheel spead sensor!!! nightmare!!!!!
thanks very much again.
james!
'Curly Q. Links'
Guest
Posts: n/a
Re: honda accord abs problem// curly q!
> james!
You can slip off the rear disk using an impact driver for the Philips
screws, then inspect and clean the sensor. More likely corrosion in the
rear connector on the backside of the rear axle. check that first.
'Curly'
Carl Gerhold
Dec 13, 2020 11:10 PM
apexanimal
Aug 29, 2015 09:09 PM
jazzy29
Oct 11, 2005 12:31 PM
jazzy29
Oct 6, 2005 03:31 PM
TeGGeR®
May 28, 2005 04:41 PM
