Crush Washer
Old Oct 12, 2005 | 04:34 PM
butch burton
Guest
Posts: n/a
Re: Crush Washer
I used the same one on a honda for 15 years and 200K miles - almost no
drips. Only have 8 years and 190K on the current crush washer - expect
to get at least 250K out of this one.
BE
Guest
Posts: n/a
Re: Crush Washer
<76steelers@bellsouth.net> wrote in message
news:1129147256.865560.115870@f14g2000cwb.googlegr oups.com...
>I don't have a Honda Dealer close by. Can I go to my local hardware
> store to get a crush washer? Or is there something special about them,
> that they have to be bought at the Honda Dealer?
I bought a bunch on-line... Google it...
Guest
Posts: n/a
Crush Washer
Old Oct 12, 2005 | 05:30 PM
Elle
Guest
Posts: n/a
Re: Crush Washer
I have started buying OEM honda oil filters and crush washers and any other
parts I think I'll need in the future (to save on shipping) at
www.slhonda.com.
I have a vague recollection Autozone and Pep Boys sells crush washers, too.
Don't re-use the old washer. They lose their "spring" after awhile (like
after one use?), which means you'll have to torque more for the same amount
of sealing effect. Ultimately risking the stripping of threads.
Paul
Guest
Posts: n/a
Re: Crush Washer
: I don't have a Honda Dealer close by. Can I go to my local hardware
: store to get a crush washer? Or is there something special about them,
: that they have to be bought at the Honda Dealer?
When I could no longer find the real crush washers (metal and rubber), I
started using the nylon kind. They work quite well, but they can be a bit
difficult to find. Pep Boys used to carry them, maybe still do.
The all-metal kind you can get from the dealer work OK too.
Paul
Old Oct 12, 2005 | 07:30 PM
TeGGeR®
Guest
Posts: n/a
Re: Crush Washer
76steelers@bellsouth.net wrote in
news:1129147256.865560.115870@f14g2000cwb.googlegr oups.com:
You can use anythng you like. If you substitute nylon or gasket material,
drop your torque to 20 ft/lbs from 33, otherwise you risk overstressing the
pan threads.
Actually, I use the Honda all-aluminum washer sold up here, and torque to
31 ft/lbs. I used gasket material for years.
TeGGeR®
www.tegger.com/hondafaq/
Old Oct 12, 2005 | 08:30 PM
SoCalMike
Guest
Posts: n/a
Re: Crush Washer
im still using the same crush washer that came with my 98 civic. thats
something like 10 oil changes, no leaks. so if you cant get one
immediately, dont sweat it.
Old Oct 13, 2005 | 07:31 AM
mikepier@optonline.net
Guest
Posts: n/a
Re: Crush Washer
I got mine from the local auto store.
Old Oct 13, 2005 | 09:30 PM
TeGGeR®
Guest
Posts: n/a
Re: Crush Washer
"Burt Squareman" <BurtSquareman@none.com> wrote in
news:a4D3f.2903$7h7.1995@newssvr21.news.prodigy.co m:
> "Paul" <paulDONTSPAMMEmueller@mindspring.com> wrote in message
> news:v4f3f.13849$QE1.116@newsread2.news.atl.earthl ink.net...
> Never heard of all-metal kind.
That's all you can get in Canada from the dealer.
Doesn't matter one whit whether there's rubber in the washer or not.
Successful sealing is quite independent of the materials used.
TeGGeR®
Burt Squareman
Guest
Posts: n/a
Re: Crush Washer
"Paul" <paulDONTSPAMMEmueller@mindspring.com> wrote in message news:v4f3f.13849$QE1.116@newsread2.news.atl.earthl ink.net...
Burt Squareman
Guest
Posts: n/a
Re: Crush Washer
<76steelers@bellsouth.net> wrote in message news:1129147256.865560.115870@f14g2000cwb.googlegr oups.com...
The one from the dealers is an exact fit. The all-aluminium crush
washer from the hardware store will come in all shape and sizes,
which works fine if they cover the nut.
Reusing them can lead to leaks months later or risk scarring the oil
pan's washer surface because of debris and the tendancy to
overtighten. Once scarred, you may never reuse any washers.
Old Oct 14, 2005 | 09:31 AM
Frank Boettcher
Guest
Posts: n/a
Re: Crush Washer
On 12 Oct 2005 13:05:29 -0700, "butch burton" <spacetrax@wi.rr.com>
Ditto. I've used the original on my 90 accord. Estimate 50 oil
changes. Carport floor is still clean as a whistle.
Frank
Old Oct 14, 2005 | 10:30 AM
Guest
Posts: n/a
Re: Crush Washer
Thanks everyone for the input.
Old Oct 15, 2005 | 06:37 PM
Mike Doyle
Guest
Posts: n/a
Re: Crush Washer
Has anyone tried the Fram Sure Drain?
It replaces the drain plug with a one way
valve. You remove the cap, & attach a
drain hose. Drain the oil right into an
empty jug.
Old Oct 15, 2005 | 09:40 PM
jim beam
Guest
Posts: n/a
Re: Crush Washer
> empty jug.
i wouldn't. just another point for potential failure. it gets real
expensive to dump your oil on the freeway 2 hours from civilization.
Mike Doyle
Guest
Posts: n/a
Re: Crush Washer
>> empty jug.
I don't see why this would be more likely to fail than the drain plug.
I've run one for over a year in a Chevy truck with no problems, &
put one on my 94 VX when I bought it. So far, no problems, no
crush washers.
YMMV
jim beam
Guest
Posts: n/a
Re: Crush Washer
>>> empty jug.
> crush washers.
> YMMV
mike, /you/ can do whatever you want. /i/ wouldn't use it. with a
standard plug, you only have the threads and washer to fail. and those
are pretty reliable. with a drain attachment as you describe, you have
the thread, the washer, the valve mechanism, the valve seal and an
unproven material. /you/ may be happy with this on your vehicle, but it
is unarguably a significant increase in points of potential failure!
Old Oct 16, 2005 | 02:34 AM
Burt S.
Guest
Posts: n/a
Re: Crush Washer
"Mike Doyle" <sigifrith@frontiernet.net> wrote in message news:GSh4f.9984$cg.3986@news02.roc.ny...
> crush washers.
I don't know how many times I've driven over uneven road surfaces,
curbs or debris on the freeway. This is a failure waiting to happen
if Fram Sure Drain is protruding like this image:
http://www.motorcities.com/photo/vie...38026C.jpeg/0/
The Fram Sure Drain is spring loaded (see image at bottom) with
a tightness of about 5-8 lbs then why would Honda specify 28-30
lb for a nut and washer?
This device also uses an o-ring which can age over time. There are
no o-rings comparable to Honda genuine o-rings. This device also
has a small opening, probably in conjunction with a spring,
could prevent large debris such as crud from fully draining which
could wreck the motor.
Overall, Honda's oil pan nut is one solid object with large openings
that is designed well, practical and predictable.
http://rustysoffroad.com/media/fram/...redrain_05.jpg
Old Oct 16, 2005 | 10:31 AM
Kevin in San Diego
Guest
Posts: n/a
Re: Crush Washer
The oil drain plug is a simple easy to get to and use device. The only thing
I would consider putting a valve in is my boat motor. That plug is
impossible to get to and I have to vacuum the oil out through the dipstick
in order to change it.
KH
"Burt S." <BurtSquareman@none.com> wrote in message
news:Bcm4f.4109$Zv5.430@newssvr25.news.prodigy.net ...
>> crush washers.
Old Oct 16, 2005 | 11:35 AM
butch burton
Guest
Posts: n/a
Re: Crush Washer
"This is a failure waiting to happen
if Fram Sure Drain is protruding like this image"
Someone has a web site in which they have disassembled every major
brands oil filters and revealed how these things are put together.
ALso on that site are comments by former people who worked for Fram
before being bought out by allied signal. If their "valve" is anything
like what they have done to oil filters - RUN.
Sparky Spartacus
Sep 28, 2005 07:18 AM
Jamous Li
Jul 27, 2005 01:43 AM
miller_m
Jul 11, 2005 09:18 AM
soniavantassel@yahoo.com
May 4, 2005 04:44 PM
pencilcup
May 4, 2005 11:16 AM
