carbon fiber roof
Old Sep 21, 2008 | 12:54 PM
kylerwho's Avatar
spoon fed
carbon fiber roof
I was looking and it seems like it could be a separate sheet of metal that is attached to the top of the car. is it possible to make a carbon fiber replacement of the gd3 roof?
Old Sep 21, 2008 | 07:21 PM
HONDAMATIC's Avatar
its welded and bonded on.. you cant just remove it
Old Sep 21, 2008 | 07:23 PM
kelsodeez's Avatar
UNBANABLE
spot welded onto the roof. it can be taken off by drilling out the spot welds.
Old Sep 21, 2008 | 07:49 PM
kylerwho's Avatar
spoon fed
spot welds are easily removed. any other way it is bonded to the roof? you could get a carbon sheet and screw it on where the old roof was as long as there is sufficient bracing.
Old Sep 22, 2008 | 02:46 PM
Tofuman's Avatar
they're called roof caps. i don't think anyone has made one for the Fit yet, but it could always be custom made ($$$).
Old Sep 22, 2008 | 02:49 PM
revd34's Avatar
or you can try carbon fiber stickers. i wouldn't want to screw anything into my roof unless its a spoiler into the hatch area
Old Sep 22, 2008 | 08:21 PM
kylerwho's Avatar
spoon fed
there is a company up here in seattle that does custom carbon fiber and fiber glass work. i should hit them up to see what it would cost. wonder how much weight will be reduced. 10lbs?
Old Sep 22, 2008 | 08:49 PM
PwRmAd's Avatar
It would add weight unless you actually replaced the roof. Or unless your talking about replacing only the top sheet metal layer. then it would barely save you any weight.
Old Sep 22, 2008 | 10:24 PM
kylerwho's Avatar
spoon fed
hmmm. need to find a fit skematic to see what could be replaced with carbon.
Old Sep 23, 2008 | 04:17 AM
Tofuman's Avatar
light weight wheels would be the most beneficial to performance. as far as body panels, maybe the front fenders. they are metal, it would take some of the weight off the front end to make the F/R weight balance a little better.
Old Sep 23, 2008 | 07:37 PM
kylerwho's Avatar
spoon fed
i think cutting weight off the top will help keep the weight toward the bottom to keep body roll even lower. But i just dont know how much weight will be saved.
Old Dec 12, 2009 | 11:35 AM
FITMugen's Avatar
09-10 honda fit carbon fiber roof top cover body kit
I just saw one on eBay but it was for GE8.
09-10 HONDA FIT CARBON FIBER ROOF TOP COVER BODY KIT:eBay Motors (item 250547114184 end time Jan-10-10 17:04:26 PST)
Old Dec 12, 2009 | 11:53 AM
dewthedew's Avatar
check out the pictures of the fit on hondapartscheap.com very helpful
Old Dec 18, 2009 | 03:35 PM
MNfit's Avatar
actually when I had hail damadge the roof was so heavily damaged they just replaced the whole skin, so it can be dont.
Old Dec 18, 2009 | 03:38 PM
HONDAMATIC's Avatar
yeah i know that but its still welded on.. so its not like you can pop it off at home and put a new one on
Old Dec 18, 2009 | 03:54 PM
JDMxGE8's Avatar
Yes it's possible to get a carbon roof cap or a replacement roof, but be prepared to pay mad money.
Old Dec 21, 2009 | 02:41 AM
qbmurderer13's Avatar
Cutting the roof off to replace it with a carbon fiber roof that weighs probably 3 pounds less... Really? Just take a crap before you drive.
Old Dec 21, 2009 | 12:31 PM
TurboManGT's Avatar
I lol'd
Old Dec 21, 2009 | 01:01 PM
dewthedew's Avatar
for real its a thin piece of metal.. it doesnt weight that much.
SixFootFiveFits
28
Oct 8, 2013 10:56 PM
cjecpa
Upstate New York Community
Aug 15, 2012 07:22 PM
jjeleven12
Apr 7, 2011 11:55 PM
kelsodeez
Sep 15, 2007 06:16 PM
