Need help with wireing...
Old Nov 24, 2008 | 05:25 PM
terrykim321's Avatar
ok... i had my subs and amp installed a while back. I had to take out the subs bc I need to move some boxes and need the extra space. Without thinking i just unplugged to wires from the subs and amp and left them siting there. Couple days later, after the bank my car wont start. I thought it was the battery but it wasnt. I took it to honda and they said that the open wires touched something metal and fk'd up the fuse and they fixed it. Also they said that they "had to" unplug my subs bc of honda standards or something. So basically, if anyone knows what I need to reconnect to get the subs workiing I'd appreciate it.
Old Nov 25, 2008 | 02:14 AM
setter11's Avatar
Well by you saying "Without thinking i just unplugged to wires from the subs and amp and left them siting there." that sounds like you unplugged the RCA Connection because those are the only wires from the amp that can be "unplugged" and those do not generate a current that would blow a fuse...
and if a fuse did blow it would be the fuse on the amp or the inline fuse on the power cable...
but besides all that, its hard to say what they "had to" unplug with out seeing pictures or a clear description... The wires that you would need to re-attach would be one of the following:
1. 12V (Power Cable)
2. Ground Wire
3. Remote Wire
4. RCA Connections
Old Nov 25, 2008 | 02:17 AM
setter11's Avatar
Here is a Crude Representation of the Amp Wiring Diagram
Andrewi56
Apr 5, 2015 01:57 PM
GotFitB13
Mar 9, 2015 08:22 PM
MookHustle
Aug 23, 2009 07:13 PM
Rubba Burna
Jul 10, 2009 10:29 PM
ratedz
Jan 6, 2009 08:54 AM
