Detailed my 2009 TW Fit
Old Dec 24, 2008 | 10:51 PM
qbmurderer13's Avatar
Hey guys, I been so busy lately I havent been able to even wash my car in quite a while. Been putting my customers cars before mine
Anyways here are the pics.
Wheels before:
Letting the P21S wheel gel soak for a minute
Foaming the car with Chemical guys citrus wash & clear
After that was rinsed off I used the 2 bucket method with dodo juice born to be mild shampoo. Quickly dried off with my craftsmen 265mph blower and put into garage to finish the minor details.
Door jambs were quite dirty
That was easily cleaned with some Optimum no rinse
After clay baring the car with Zaino Z18 and optimum gloss enhancer I wiped it down with some Isopropyl alcohol to remove any remaing oils or water that I missed from drying. I put the car under the halogens to see if there was any swirls or scratches.
Thankfully ive been taking good care of it so there hasnt been any swirling. Either way I decided to polish with using menzerna 106fa on a white pad just to bring the paint a little more gloss. Didnt get any pictures of this process though. After that I applied Meguiars #21 using a red ccs pad on my porter cable and let it haze for about 8 hours.
Buffed off and removed any remaining dust using Zaino Z6 and applied Z16 tire gloss and took it outside for some pics. Not the best since it was getting dark and didnt feel like moving the car to a better location. Also my camera sucks...
Thanks for looking!
Edit: Added some better pictures and sun shots from the following morning.
My arsenal:
Old Dec 24, 2008 | 11:36 PM
Tofuik's Avatar
dude.. seriously... you're hardcore, thats a damn good cleaning job
Old Dec 24, 2008 | 11:54 PM
Appreciate all the kind words guys. This was just a quickie too only took me 4 hours. Most cars I do are trashed and take me 8 to 10 hours. Although white is very good at hiding swirls and other defects. Black is a different story!
Old Dec 25, 2008 | 12:36 AM
Super Mario's Avatar
Can the #21 Synthetic Sealant be applied by hand? I'm already using Meguiar's Hi Tech #26 + NXT Wax 2.0 on top of that. Would you recommend the synthetic sealant too?
Old Dec 25, 2008 | 12:45 AM
#26 is a really really good product. Its my most used wax. I personally wouldnt put nxt 2.0 together with it though. They are both essentially the same thing. #21 can be applied by hand and lasts 3 times more than nxt does. I would put a coat of #21 and left to cure for at least 4 hours. After you remove that you can top with a thin layer of #26. If you put too much youll be removing the #21.
Also another tip after you wash and dry a car mist the car with Isopropyl alcohol (rubbing alcohol) and just wipe away. This will help remove any glazes or old wax residue and gives the sealant a better surface to bond too. I find by doing this adds at least another month to durability.
Old Dec 25, 2008 | 01:14 AM
mike410's Avatar
Damn I bet you car looks better than it did when it was new!!!
If I ever spend that much time washing my Fit I hope it would turn out half as good. Hopefully I will remember the isopropyl alcohol tip, because it seems useful
Old Dec 25, 2008 | 02:51 AM
jamiev's Avatar
Great job there!
Old Dec 25, 2008 | 02:55 AM
JDMxGE8's Avatar
So fresh, so clean clean!
Old Dec 25, 2008 | 02:56 AM
Interesting. I'll look into your advice. I thought that since the #26 is mostly carnuba, and that the NXT is pure synthetic that the synthetic will act as a sealer over the carnuba.
I remember in the Summer, waxing the car with just the #26 and it didn't last long at all. Maybe a week or two. Then I used Quik Wax + NXT and that's still on there right now. Not much, but still smooth to the touch. It's been about 2 months at least.
Old Dec 25, 2008 | 01:04 PM
Well sealant is supposed to go under carnauba. Like I said if you do an isopropyl wipe down before applying wax or sealant it will last longer. Nxt looks great but its known for its poor durability. I would just apply #26. After you buff it off you can also use meguiars quick ultimate detailer. This will remove any wax residue you mightve missed and add a little bit more protection since it contains carnauba.
Old Dec 25, 2008 | 01:09 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
damn dude you can tell you do it for money
great job
Old Dec 25, 2008 | 06:41 PM
davela72's Avatar
The car looks great. I'll be using the Optimum No Rinse throughout the winter but might purchase a foam gun for the summer. Did you spray the car with the foam gun and then rinse before you washed with the mitt? I was thinking you could use the foam gun and go right to washing with the mitt?
Old Dec 25, 2008 | 06:51 PM
Yeah I pre soaked the entire car with it then rinsed it off. I just did that to remove the previous wax as the CG soap I used is very strong. When I'm just washing it I foam the whole car once then rinse off to get most of the grime off. Then do each panel at a time by foaming, then dipping the mitt in a bucket of clean water with a grit guard and wash each panel. Optimum no rinse is an awesome product by the way. Its almost 90 degrees here today and I still use ONR.
Old Dec 25, 2008 | 08:18 PM
doctordoom's Avatar
Supervillain
dang i can't really tell from your pics but i bet your car is immaculate.
Old Dec 25, 2008 | 09:47 PM
davela72's Avatar
Gotcha! I just found a few videos on Autogeek and they use the foam gun as you said, thanks for the info!
Old Dec 25, 2008 | 10:46 PM
Tofuik's Avatar
thanks for the alcohol advice, I'll try that whenever I get around to cleaning my car >.>
Old Dec 27, 2008 | 01:23 AM
Updated with better pics.
Old Dec 27, 2008 | 04:29 AM
08_Nick_Fit's Avatar
were can I get one of those foaming device thing? haha
Old Dec 27, 2008 | 07:57 AM
davela72's Avatar
Amazon is by far the cheapest I've seen them, $35 or so.
Old Dec 27, 2008 | 02:02 PM
1coolride's Avatar
amazing!! looks way better than before. brings out alot more shine when its cleaner
Edison Carasio
Jun 11, 2010 01:53 PM
808hondajazz
Jan 6, 2010 03:03 AM
junior40er
Jul 2, 2009 09:51 PM
Sid 6.7
May 14, 2009 12:45 PM
qbmurderer13
Mar 14, 2009 01:25 PM
