09' Fit Cargo Shelf Cover dilemma
Old Mar 22, 2009 | 12:26 AM
RaXeT's Avatar
Angry 09' Fit Cargo Shelf Cover dilemma
The detailed instructions for installing the solid piece cargo shelf are a joke! States that all you need is a Phillips screw driver, push pins, tape measure and a felt tip pin. First off, you can't screw the blasted snaps with covers in at all! Behind the material for those seats are some type of metal frame.
The first placement is on the right rear seat states 2.2 inches (assuming 2" 1/4?) from the left side, and 1.7 inches down. Try turning that Phillips screw driver in one of those snap heads. It won't puncture the solid metal frame of the seat behind that felt backing. You would need an electric drill!
There is absolutely no way to install those snaps with covers. Poorly thought out by whom ever.
Anyone else have the answer?
Old Mar 22, 2009 | 12:56 AM
dman's Avatar
There are pre-drilled holes for the screws. You just have to feel around through the felt for the depressed areas on the felt. No need for a drill.
Old Mar 22, 2009 | 01:02 AM
Trogdor!'s Avatar
Exactly! That's what the push pins are for. I used it to kinda feel around through the carpet. Just make sure it's in the metal frame. I made a mistake on the first button and thought this other recessed area that was just a little off the measurement was the right hole and stretched the carpet a little where I tried to screw the button in.
Old Mar 22, 2009 | 01:22 AM
CBX's Avatar
CBX
Mine went well using the pushpin method too. Just take your time finding each pre-drilled hole, and it will screw right in.
Old Mar 22, 2009 | 01:37 AM
RaXeT's Avatar
Thanks man. I guess I'm not as intuitive as I thought.
Old Mar 22, 2009 | 01:44 AM
reako's Avatar
Or you can just do nothing and let the flaps and buttons dangle down for 2+ months...MAN I'm lazy.......
Old Mar 22, 2009 | 04:35 PM
cardinal's Avatar
I put the snaps on, but have left the flaps hanging for months. I flip the seats around too much to be bothered.
Old Mar 22, 2009 | 06:40 PM
crazy cuban's Avatar
I let the dealer do it for me. It's perfect!
Old Mar 22, 2009 | 07:33 PM
FireFox91's Avatar
There was another thread about this but I am too lazy to go find it. Basically, my solution was to not even put the snaps in. Use some needle nose pliers to pop off the caps holding the fabric to the shelf. That way you still get a clean presentation with no hanging fabric and you don't have to cut it off.
With the seats in the reclined position, there is only a 1/2 inch of space to look into the cargo area. You can't see anything through this little amount of space, especially so if you have window tint. The fabric and snaps are just a hindrance to you getting cargo in and out. I know for sure that if I installed the snaps I would have ripped them off sliding something into the back at some point. And the leftover fabric can be used for something else. In my case is was used to make a sweep on the gate to my backyard to keep the cat from getting out. Apparently she found another way out. :/ Stupid cat.
Old Mar 23, 2009 | 12:02 PM
that felt hanging thing is a joke. im going to remove mine pretty soon.
it's just an inconvenience than anything. just use the tray part of the
cover along with the rope and hook.
Old Mar 23, 2009 | 12:09 PM
JDM_DOHC_SiR's Avatar
1st thing I did!!.... I removed that flap with a quickness..
Old Mar 23, 2009 | 07:08 PM
reako's Avatar
Nice! I'll try this later...thanks!
Old Apr 6, 2009 | 11:16 PM
SanDan's Avatar
thanks for the tip. I didn't even realize the rear seats could recline. This mod actually made me feel not so gypped by honda's cargo cover.
Not sure if you really need plyers to remove flaps though. I just pulled it off, and off came the plastic.
Old Apr 7, 2009 | 10:24 PM
TaffetaWhite's Avatar
Someone that spends her life on FitFreak.net
Wait! The rear seats recline???
Old Apr 7, 2009 | 10:26 PM
Lightbulb
Sure do... but only about 3~4 inches tops..
Old Apr 7, 2009 | 11:59 PM
wskwong's Avatar
any cheaper alternatives out there yet? paying 200 bucks for a piece of plastic is a bit too much.....
Kittengolf's Avatar
I learn something new every day.
Old Apr 8, 2009 | 11:59 AM
FireFox91's Avatar
A really nice cardboard box.
You are right, that price is way too much for what it is. But, anything else makes it look like you are hiding something which might encourage someone to go ahead and break in. The shelf look like factory equipment because it essentually is. You can get it for cheaper from College Hills Honda. Still expensive, but required if you want to keep prying eyes out of your trunk. There is no aftermarket option on this I am aware of.
Old Apr 8, 2009 | 12:07 PM
dela's Avatar
5% rear tint?
i was thinking of buying the rear cover.. but i cant justify spending $200 on it... just gonna get dark rear tint haha
Old Apr 8, 2009 | 02:42 PM
FireFox91's Avatar
Originally Posted by dela
5% rear tint?
That would work too until the cops decide to inform you of your illegal tint. I have 15% myself and I still wouldn't leave it with tint alone.
