FS: Mediagate MG-35 multimedia player (dvds,video,music,photos,streaming)
Old May 3, 2009 | 08:47 PM
suketoborudo00's Avatar
Everything originally included is repackaged in the original box as if you got it brand new. Everything is in great condition and I just bought a new battery for the remote. Letting it go for $60 local pickup. For $80, I can add an 80GB harddrive to get you started.
Basically a stand-alone multimedia player that can support up to 500GB internal harddrive or can stream video from PC to your TV.
Primary purpose I used it for was to download TV shows, transfer the video files to the media player and then watch on my TV. Now I just watch them on my PC since I can't play HD videos on my TV.
It has other functions such as photo viewing and music playing but wasn't something I intended to use the device for.
It has a remote to control all the functions as well as navigation buttons on the device itself. Worked out great for me, but want to sell and let someone else enjoy this.
Here is the description from the company's website:
-MEDIAGATE MG-35 is a high-performed, DMA with 3.5-inch HDD inside.
-The MG-35 has a 10/100 Ethernet port so home PCs in the same subnet can be easily accessed.
-As the price of 3.5-inch HDD is the lowest compared to other sizes, users can easily install up 750GB IDE hard drive for storing digital movies.
-The MG-35 has a USB2.0 slave port. It provides an alternative way to download digital contents from the PC.
-The MG-35 can be provided without 3.5-inch HDD. In this case, it can be a low-cost DMA without HDD.
-The MG-35 can be configured in collaboration with web-based movie distributor as a set-top box or media gateway to access, play and/or download the legal movies from the website directly without home PC.
-The MG-35 is an optimal solution as OEM or ODM product for who want a high-performed DMA. The DMA is designed to be flexible and easily fits into the customer's requirement.
# Has one 10/100 LAN port
# Supports USB2.0 slave
# 3.5-inch HDD is user-installable
# Supports MP1/2 MP@ML, MP4 ASP@L5, 4.x and 5.x, JPEG
# Supports composite, S-video, component video outputs
# Supports Dolby digital, MP1 and MP2 Layers I, II and III (MP3), WMA
# Supports stereo L/R, optical/coaxial digital audio, analog 5.1 channels
# Supports JPEG still picture
# Enables file surfing from multiple sources on TV using a remote controller
Gernal
Product Name: MEDIAGATE MG-35
Power: DC 5V / 1.5A, 12V / 1.5A
Weight: 250g (Without a HDD)
Dimension: 57 x 150 x 185 mm
Working Temperature: 0-50ç°
Working Humidity: 10%-75%
Interface & Other
Operating Systems: Windows 98/SE/ME/2000/XP, MAC 9.0 higher Linux 2.4 higher
PC Inerface: USB 2.0 (USB 1.1 compatible)
HDD Type: 3.5" IDE HDD
HDD File System: FAT32, NTFS
TV Type: PAL, NTSC
Supported Formats: Movie: MPEG 1, 2, 4 (MPG, MPEG, AVI, M2V, DAT, VOB, etc) , XviD (Except GMC, Qpel option applied)
Music: MP3, OGG Vorbis, WMA
Photo: JPG
Video Out
Composite: 1Ch : 1.0Vp-p (75«ø load)
Component: Y : 1.0Vp-p (75«ø load)
Pr : 0.70Vp-p (75«ø load)
Pb : 0.70Vp-p (75«ø load)
Audio Out
Stereo 2Ch: Left (1/L), Right (2/R)
Digital Out (Coaxial): 0.5 Vp-p(75«ø)
Audio Sampling Rate: 32, 44.1, 48, 88.2, 96KHz
S/N (Signal to Noise) Ratio: 99dB
Dynamic Range: 92dB
Harmonic Frequency Distortion: 0.01%
Mediagate USA
Antpwny
SoCal Classifieds
Sep 18, 2011 11:25 PM
PostRelease
Jan 19, 2010 01:00 PM
PostRelease
Jan 19, 2010 12:59 PM
PostRelease
suketoborudo00
SoCal Classifieds
Jan 7, 2010 08:56 PM
