Fit for AutoX
Old Apr 21, 2006 | 02:21 AM
Bounty Hunter's Avatar
Fit for AutoX
How many of you are planning on AutoXing your Fit? What class will the Fit be placed in? Do you think it will be competitive?
Old Apr 21, 2006 | 02:26 AM
Ah Ed's Avatar
isn't it a b-segment car?
ezekielwhore's Avatar
if it wasnt my daily car. i would.
Old Apr 21, 2006 | 02:57 AM
JDMGD3's Avatar
The current Fit platform would make an excellent AutoX car with very little modifications, mainly good aftermarket suspension to lower it about 1.5" all the way around, some upgraded brake pads, high temp brake fluid like Motul, SS brake lines, stickier tires and front, rear and lower arm bars. That receipe would make the Fit a great AutoX car, and the engine hasnt even been touched yet.
Old Apr 21, 2006 | 11:29 AM
atlas's Avatar
yes. the Fit is an awesome car to do stuff to. the stamped aluminum steel body and the gas tank fitment is perfect for doing stuff with. i think for auto-x, as long as you lower your center of gravity and upgrade the tires, it'd be fun, but for road courses, you'd be seriously lacking power.
Old Apr 21, 2006 | 01:05 PM
JDMGD3's Avatar
Ya in the case of road racing, it would lack power down the straights but that doesnt mean it still wouldnt be fun to drive. Straight line speed is rarely a factor of a road race car that attributes or dictates if a car is going to be fun to drive because the main attraction of a road course are the corners and in the end its about how you take those corners that will help or hurt your lap time. But it wouldnt hurt the Fit at all if it had 30 to 40hp but keep in mind the Fit is a relatively light car and if converted into a road race car, can be even lighter so 140 to 150hp in a car as light as 2300lbs after a good weight reduction would equate to a pretty quick car around a road track.
Old Apr 21, 2006 | 01:12 PM
5 Zigen's Avatar
i will be auto-xing it after break in
Old Apr 21, 2006 | 04:36 PM
CarDemon's Avatar
Senior Member
This car is so ideal for Auto-crossing even on a mild budget. Hell, I'll even keep the baby on boad sign up and leave the babyseat in.
Drop springs and 14" blacksteelies and tires will do for me. The B-segment at any race is usually interesting as they are everyday cheaper cars, but I still like to see a good driver take out a more expensive Non- turboed Mini Cooper which handles like it's on rails.
Old Apr 21, 2006 | 06:01 PM
dougiepants's Avatar
Avid FitFreak Poster
Great wheel base, aggressive gearing, and low center of gravity... Awsome Auto-X car I think
Old Apr 21, 2006 | 07:18 PM
The guys at Honda-Tech say it'll be H Stock which sounds about right being the slowest class. It'll be placed against the Mini and I really don't think it has a chance nationally. However I'm sure you could still have fun locally and probably win a few races.
Old Apr 21, 2006 | 09:25 PM
I think it has a good chance against the base Mini Cooper. But we will have to see until the first person runs it.
Old Apr 23, 2006 | 03:11 AM
aywwsd's Avatar
Senior Member
thats a receipe get you out of stock class and into street prep class.
touch the engine with more then a cold air intake will have you in street modified class.
Old May 5, 2006 | 01:16 AM
Nitro22's Avatar
More like Street Touring Class (STS), which is a very fun class to compete in.
Old May 6, 2006 | 07:48 PM
I'm testing on the 20th and I'll let you know...
Old May 6, 2006 | 08:16 PM
fshwcrs's Avatar
It's probably been mentioned, but it's gonna be H-Stock and doesn't stand a chance against some of the other cars in that class (Mini, for starters)
Change your springs, wheel sizes or any number of other things that have been mentioned and...
(image changed from original to set a better example )
even harder than you would if you stuck around in H-Stock.
But if you're not in it to win it, it should be lots of fun.
Old May 7, 2006 | 02:32 AM
07Fit00S2K's Avatar
I'll probably autox the Fit once after I get it. But the S2K is my autox/track car.
Old May 17, 2006 | 08:24 PM
dumplingcorp's Avatar
after i fully tune the suspension, not sure which brand yet, yokohama es100's...i need bars too (sway, strut, tie).....TOUGE MONSTER!
Old May 17, 2006 | 08:35 PM
07Fit00S2K's Avatar
The Fit is faster than a Z06 in the slalom.
Old May 17, 2006 | 09:14 PM
moeye's Avatar
Fold the rear seats down for lower CG! lol
Let me put my flame suit on and do some bench racing:
Weight
Mini (2006 Base MT): 2524 lbs
Fit (2007 Base MT): 2432 lbs
Gearing (1st, 2nd, 3rd gears only x Final Drive)
Mini: 14.40, 8.325, 5.475
Fit: 14.86, 8.029, 5.672
Not gonna go into power numbers and torque curve characteristics. Let's just say the Mini has the edge on that one. Acceleration and braking numbers are too tied in with tire compounds so I'm gonna throw those out the window. I have no idea what the moments are in the cars... cause nobody ever measures them.. so I'll leave those out too.
2nd gear doesn't look so good for the Fit, but then again the Fit has the weight advantage. Just gotta see it in action to tell!
Old May 17, 2006 | 09:19 PM
gsilvers's Avatar
The fit won't do all that bad in the class. Yes the cooper is going to be tough but it weighs alot more. ALOT MORE. Things I will be worrying about whooping my ass when I show up (Luckily alot of the people that run these cars end up in STS because of CAI's) are RSX non S, 318is, the most recent si hatch (02-05) USDM and 200sx/sentra se 2.0L's. These cars will crap on the fit. Mostly on one thing I'd think, expecialy the civic hatch and the 200 sx's. THese are both quite fast in stock class. I think a nice harness some pads and a catback though and the fit will be fun to beat up in stock class. I'm going to a test and tune in two weeks to try it out.
